Old 07-25-2009, 04:56 PM
15mgtar is on a distinguished road
newbie don't know his spindle
Hi guys, I have a question can I use ADX100-24Z/2.2 spindle motor to mill some aluminum and steel? or ADX100-24Z/2.2 is for wood working only?
Thanks in advance.
Old 07-26-2009, 01:33 PM
I have attached the pdf file of ADX100-24Z/2.2 pls someone take a look if I can use this spindle for milling aluminum and steel. Thanks in advance!
Feed rates / spindle speeds for HF spindle yngndrw General Metal Working Machines 2 03-21-2009 11:46 AM
Sweo spindle drive? new mill dead spindle Shizzlemah Fadal 13 12-18-2008 12:11 PM
Squaring the Spindle ( newbie ) Ang_Panday Bridgeport and Hardinge Mills 2 09-01-2007 06:49 AM
Lathe spindle bearings and spindle material mackeym General Metal Working Machines 28 08-21-2007 03:49 PM
Lathe spindle bearings and spindle material mackeym Linear and Rotary Motion 1 08-11-2007 11:53 AM
