Old 07-25-2009, 02:32 AM
sinha_nsit is on a distinguished road
machining tensile test specimen
I need to machine a test specimen for a tensile test machine. The dimensions are given in the attached file. What would be the best machining method? One has to use a round insert because left-hand, right-hand as well as neutral tool with diamond-shaped insert will all cause interference at the shoulder which has an arc at 90 degree. Do I have to machine the left shoulder (say, from half the length to the left shoulder) using right-hand tool, right shoulder using left-hand tool, leaving some allowance, to be followed by neutral tool with round insert, for finishing? Or can everything be done by the neutral tool with a round insert? If yes, what can be maximum depth of cut with the round insert of diameter 6 mm, if the workpiece is mild steel? I have an intuitive feeling that a round insert is not meant for heavy cuts (say, 1-2 mm), specially when it plunges into the workpiece, before straight turning starts. Am I correct?
Name:	tensile test specimen.jpg‎
This is a test thread in the test forum adam.faris Test Forum 1 10-27-2008 12:21 AM
MIS CNC Machining and tooling - General machining - Thermoform Molds modernprecision Employment Opportunity 0 11-23-2007 11:05 PM
tensile strength pp-TG Mechanical Calculations/Engineering Design 14 11-30-2006 08:14 AM
Machining anodized parts or anodize after machining? SRT Mike General Metalwork Discussion 4 03-12-2006 12:22 AM
