Old 07-24-2009, 10:06 AM
protrxrptr17 is on a distinguished road
Cutting double keyways
I need some pointers on cutting double keyways in a shaft. Its a 2 7/16 with 5/8 keys 180 degrees apart. I've been doing it by scribing lines across the end with a center finder and lining it up with a level. Theres gotta be a better way. It has always worked out OK, but I just don't feel like its the most accurate way to do it. I'm cutting it with a knee mill and a 5/8 end mill. The lumber mill is waiting on me right now, so a quick reply would be much appreciated.
Old 07-24-2009, 01:44 PM
Andre' B is on a distinguished road
I have clamped a large V block to the shaft, and cut one keyway with the block sitting on one side on the machine table and the shaft clamped in a vise. Us parallels and shims as needed to level things up.
To do the other keyway just turn the shaft over so the V block is sitting on it's other side.
Even if you do not put the keyway perfectly on center the second one will be exactly 180° as long as it is a good V block and you do not change the distance from the cutter to the fixed vice jaw.
Old 07-26-2009, 07:48 PM
Mcgyver is on a distinguished road
on smaller shafts I've done the V block thing, but that’s a big one. Why not clamp to the table, in a t slot, and use a keyway cutter, run it up and down both sides with one set up....it'll do a better job than an endmill. Move clamps as necessary to complete
Old 07-27-2009, 12:58 AM
crabbass is on a distinguished road
On long pump shafts with keys spaced 180 apart, I have used a Miracle Point.
It is a magnetic Vee with a point to the centerline of the shaft. It has a mercury balanced dial. This isnt my preffered method, but the miracle point is a damn handy tool in the shop
Tool for cutting internal keyways etc... M-man CNC Tooling 7 08-19-2010 11:05 PM
Newbie- Newbie needs help! cutting acrylic, and double cutting? 3040 machine stephaniehamer Laser Engraving & Cutting Machines 5 06-29-2009 04:37 PM
Do all R8 collets have keyways? slashmaster General Metalwork Discussion 6 05-11-2009 09:42 PM
In line keyways zooloader General Metalwork Discussion 3 12-05-2007 10:49 AM
I need help with keyways! iprogcnc GibbsCAM 2 10-08-2007 06:39 PM
