Old 07-21-2009, 03:28 AM
matttay is on a distinguished road
Ballparking Tool Life and Cost
Hi, assume you had the time and patience to dial in a setup that needed to optimally remove 3-5 in3/minute of material in 316 stainless.
How long would you expect a cutter to last before it needed replacing? How much would you expect that cutter to cost?
Would those figures change appreciably for 303 or 304 SS?
An answer such as "We get about X hours of milling time in 316 on a Y-brand 0.5" end mill, and those are about Z each" would be extremely helpful.
Thanks very much!
Old 07-22-2009, 08:14 AM
PixMan is on a distinguished road
There will be a big difference in tool life of an end mill between milling 303 and 304 stainless, probably 2 times the life.
There is such a wide variety of tooling and the operations you do with it out there that it's just about impossible to predict. You will need to test.
You might be able to get a tooling vendor to predict. What is the type of milling operation (face, end, side), the depth of cut, width of cut, diameter of tool, etc?
Need Help!- CBN tool life? Pontiff51 General Material Machining Solutions 2 02-27-2009 07:15 AM
Tool Life chrisryn General Metalwork Discussion 0 06-12-2008 11:06 AM
Tool Life stampman Fanuc 0 07-31-2007 02:30 PM
Tool life Muzzy CNC Tooling 0 04-11-2007 05:47 PM
Tool Life & Cost/Price Analysis thkoutsidthebox CNC Tooling 12 02-16-2007 06:23 PM
