Do not try using a die if you want to have quality threads. That is way to much stock to remove. Turn to proper dia then single point threads to remove most of the material. Once you have rough threads about .015 over pitch diameter then chase with the die. Best quality would be to finish with the single point tool.
LinkBack URL
About LinkBacks
