Old 07-19-2009, 01:17 AM
ranchak is on a distinguished road
Cutting tubing to length on lathe?
I need to cut/trim some 5/8, .045 wall SS tubing to length. The pieces are rough cut to size with one end squared. I need to cut/trim the tubung to length with .010". Is there a way to install a stop inside the spindle and use an adjustable carriage stop to do this?
Old 07-19-2009, 08:46 AM
Do you have access to the end of the spindle?
One way to make a simple stop is make a cap with a hole through it, that fits over the end of the spindle and is secured by three setscrews. Then run a length of threaded rod through the hole and have a plug screwed on this rod inside the spindle and just adjust it to the correct position and secure it with a nut either side of the end cap.
Just remember to cut off any excess threaded rod wagging about at the end of the spindle and make a bit of a guard.
Old 07-19-2009, 09:13 AM
Vogavt is on a distinguished road
@ Geoff
I can't wrap my mind around this. Can you post a diagram?
Old 07-19-2009, 09:48 AM
Originally Posted by Vogavt View Post
@ Geoff
MyCAD skills are non-existent but pretty colored pictures I can manage.
I left out the setscrews and nuts.
Old 07-19-2009, 10:09 AM
Al_The_Man's Avatar
You did not mention if this was CNC or manual, the principal many of the tube cut-off machines work, is a bar feeder arrangement feed the tube through the chuck to a programmable stop, when the chuck closes, the stop backs off to allow the tube to rotate and be cut.
This is assuming you have full length material to be cut into short lengths.
I just completed a retro-fit of an old Modern Tube cut-off that uses this method.
Old 07-19-2009, 02:05 PM
Sorry, I forgot to mention that this is manual, these are pieces that are rough cut to length. Geof has the idea I was looking for, that will work perfectly for me. Thanks, Ron
Old 07-19-2009, 08:06 PM
maz43's Avatar
maz43 is on a distinguished road
If you are using standard soft jaws you can drill and tap a hole in the back of one of the jaws and insert a threaded rod. Tap a small piece of flat stock for the adjustable stop. It may be a cheap simple solution, but it has worked just fine for me.
lathe oils (way, cutting etc) help Speedygonzales General Metal Working Machines 0 07-11-2009 06:41 PM
Table length cutting problem? Blacksunshine WoodWorking 4 03-13-2008 08:00 PM
setting lathe tool length offsets on ah ha control machinewerks G-Code Programing 2 02-27-2007 09:09 PM
Website update - Lathe Project & Fixed Length Tooling Hack Product Announcements & Manufacturer News 0 06-10-2006 10:25 AM
cutting tubing with CNC waterjet webcruiser8 CNC Plasma and Waterjet Machines 2 02-06-2006 03:08 PM
