Old 07-14-2009, 11:59 AM
chippslinger's Avatar
chippslinger is on a distinguished road
Question HEEEEELLLLLLPPPPPPPP
Here is my problem. I have a program that is over 8000 lines long and I need to move it to another machine but in the process I need to rotate 90° about the Z-axis therefore making whta used to be x axis moves y axis moves and vice-versa. I dont want to repost the program because of all the changes that have been made at the machine. Is there a program that can read my cnc program and swap the x and y axis numbers for me to make the process quicker??
Michael J.
Old 07-14-2009, 12:12 PM
HuFlungDung's Avatar
Moderator
I've not done that sort of thing in a long while, but most editors should be able to do this. I think the trick is first to change all the X's to some other unused letter like maybe U or W (think carefully!) Then change your Y's to X's, then change your U's (or W) to Y's.
You'd probably have to change arc center coordinates with a similar method.
Then you should run the program through a simulator to see if it still looks right, maybe something like NCplot.
Old 07-14-2009, 12:34 PM
beege's Avatar
beege is on a distinguished road
Do you have coordinate rotation on the victim machine? rotate it 90°!
Old 07-14-2009, 12:49 PM
Do you have any G02 or G03 moves using I and J? You may have to switch these as well.
There is a company called editcnc that has an editor that can probably do this.
http://www.editcnc.com/
I am not asociated with the company but I have dealt with it.
Old 07-14-2009, 03:29 PM
maz43's Avatar
maz43 is on a distinguished road
Google PC DNC editor. Suburban software has a free trial editor that will rotate, offset, swap axes and mirror.
Good luck
Old 07-14-2009, 09:07 PM
*Registered User*
fpworks is on a distinguished road
also check NCPlot
Old 07-15-2009, 04:57 AM
Superman's Avatar
Superman is on a distinguished road
beege started it.
What machine and control do you have ???
Okuma can use a G code to rotate an existing program. This would suit the problem you describe
IE G10 P90. any X+ values would create a Y+ movment, any Y+ coding ends up as X- moves
Many machines also have this ability.
Old 07-17-2009, 03:22 PM
msomerville is on a distinguished road
+2 coordinate rotation should be an option on the machine.
