Old 07-13-2009, 09:48 AM
Dropout is on a distinguished road
Engraving brass
Hi All.
I need to engrave some brass plaques with my CNC router.
Can anyone recommend some tools bits and starting speeds and feeds?
Thanks in advance.
Old 07-13-2009, 11:09 AM
Boots is on a distinguished road
Some Brass is Half Hard and some Hard then there is the soft stuff too. Don't know which you are using cause you didn't state but there are as many Brass Type materials as there are Steel. I use Onsrud Tools #37-06 is a .020 tip @ 60 deg. #37-07 is a .030 tip @ 60 deg. and #37-11 is a .060 tip @ 60 deg. These cut half Hard Brass very well @ 18,000 rpm @ 180 ipm. they all are $16.28 ea. US $ Smaller tips are for small letters and large tips for bigger letters.
We all live in Tents! Some live in content others live in discontent.
Old 07-13-2009, 11:17 AM
Thanks Boots.
What depth of cut do you use?
What would be a good tool for cutting through the brass (cutting a large piece into smaller plaques)?
Dropout
Old 07-14-2009, 05:48 AM
The depth of cut depends on the "LOOK" you are trying to acheive. I cut anywhere from .015 to .030 deep and sometimes go .060 . (.5mm to 1.5mm) . To cut thru I would use either a 2 flute 1/8 in. bit or a 2 flute 1/4 in. (3mm - 6mm) depending on your outline and shape. You can cut pretty deep with these Engraving bits up to the full dia. of the bit but in several passes and keep in mind the deeper you go the slower you go as you have more tool contact with the brass. Going to deep too fast can cause chatter and a poor quality finish.
Old 07-14-2009, 08:25 AM
Thanks!
Old 07-14-2009, 02:33 PM
Hi Boots
I forgot to ask, do you do this dry or use a mist coolant?
Dropout
cutters for engraving brass plate Stewey Engraving Machines 50 12-06-2011 12:35 PM
Newbie- Weld Brass to Brass piratesover40 Welding, Brazing, Soldering, Sealing 3 03-03-2008 06:02 PM
Engraving Brass Tony Mac Vectric 14 03-28-2006 10:16 AM
How can I cut Brass? cbcnc General Metalwork Discussion 3 01-13-2004 07:54 PM
Where to buy Brass? NeoMoses General Metalwork Discussion 3 10-05-2003 08:35 PM
