Old 07-11-2009, 07:35 PM
bgray is on a distinguished road
Coolant Recommendation
I have a Compact G27 lathe coming from Dynamic pretty soon.
I will be working probably 10% brass, and 90% acrylic.
Can someone recommend a brand of flood coolant?
Thanks.
Old 07-13-2009, 10:11 AM
coolantman's Avatar
coolantman is on a distinguished road
bgray,
EnviroServe Chemicals, Inc. manufacturers some of the best coolants there are. We have a full line of synthetics, semi-synthetics, and soluble oils. We will be glad to send you a trial sample of the type you would like to use.
Hope to hear from you soon.
-Coolantman
(910) 892-1791
www.enviroservechemicals.com
Old 07-13-2009, 10:47 AM
jmoore is on a distinguished road
Tricool TC1 Synthetic
Tricool TC1 Synthetic coolant -- diluted 20/1. I have used this for eight years on acrylic. It has excellent rust inhibiting qualities, it does a great job cooling and lubricating (I have taken IR thermometer readings inches behind a tool as it cut 3-inch-thick acrylic and have consistently gotten readings below 95 degrees Fahrenheit, but this can vary depending on many variables), and leaves no difficult-to-clean residue -- just wipe with a damp cloth, scuff lightly, and you are ready to bond. I have massive, 1,000-plus-gallon aquariums out there for eight years that still have crystal-clear bonds and zero crazing anywhere, that were machined using Tricool. Good luck.
Old 07-13-2009, 11:13 PM
Thanks. I'll investigate both.
www.edisonpen.com
Newbie- Band saw coolant recommendation Johan Cnczone General Metal Working Machines 0 05-28-2009 09:53 PM
CAD CAM recommendation lipolad General CAM Discussion 1 03-06-2008 10:17 AM
Coolant Recommendation for a hobbiest apeman88 Tormach PCNC 22 01-28-2008 11:04 PM
CAD/CAM recommendation split63 General CAM Discussion 9 06-11-2007 05:59 PM
Recommendation Please SPEEDRE Autodesk Software (Autocad, Inventor etc) 0 02-12-2007 05:33 PM
