Old 07-11-2009, 09:53 AM
adscnc is on a distinguished road
how to cut a 85 degree v raise female tool
I want to make a v raise die with a 85 degree form in, who's got the best suggestion on how to cut this on my vertical bridgeport mill. (8" long 1 1/4 wide 5/8" deep approx)
Old 07-11-2009, 11:49 AM
mc_n_g is on a distinguished road
Mount your part vertically. Use a form cutter for the shape you need. Form cutter (or holder) needs to be long enough so it is away from the spindle. The seperation between the 'V's is controlled by your vertical. The longer your cutter will be from the end of the spindle the more chatter you will see in your cut. You can also try a flycutter ground to the right form but may be harder to set up.
This is all based upon if I understand what you are asking.
In one year I will gradeuate with an industrial management degree.WTF is this degree? KyleH2 CNCzone Club House 3 06-29-2008 07:30 PM
Need Help!- 4020 Won't raise Z to allow tool change!! john-john Fadal 8 05-16-2008 12:53 PM
Need A Quote- knurling work need (female and male) acerocket Employment Opportunity 4 02-10-2008 03:24 PM
Calculate tool offset for degree CBNDude General Metalwork Discussion 2 10-17-2007 05:59 PM
male and female molds pyroracing85 Moldmaking 10 02-21-2005 11:40 AM
