Old 07-08-2009, 12:40 PM
rpt973 is on a distinguished road
Problem Hitachi Seiki HT 40G
The first thing to ask perdon by my bad English I am used a program for translation.
I working in Hitachi Seiki HT40g Seicos-10L Multi
My question is:
When I write a program with angles or cycle for drilling ,the program is stoped leaves an alarm NC alarm [191] Option command
NC alarm [191] Option command G01A Whith angles
NC alarm [191] Option command G80N Whith cycle for drilling
The rest of g-codes and options run well,i dont understand this?
I have lost parametres?
where I go for activate this?
someone can help me to cause to run the options.
Thanks to all
Old 07-08-2009, 03:06 PM
stevo1 is on a distinguished road
Are you sure it is not the program? Can you post the code that you are having a problem with?
If it is a parameter issue I will dig around and see what I can find. I don't know how much I have on the HT40 but I have a lot on the VK45,55,65.
Stevo
Old 07-08-2009, 04:29 PM
Thanks for you response,is not a problem of programation,whith the original books i write the same examples and don´t work.
Old 07-09-2009, 06:50 AM
Just for the heck of it can you post the example code you are trying and show were it does not work or alarming out?
Stevo
Old 07-09-2009, 01:40 PM
Ok,tomorrow i post the examples.
Old 07-10-2009, 11:17 AM
Hi,the angle format is
G01 x_ A_;
G01 z_ A _;
Example:
G0 x50 z10
G01 x52 z-1.5
z-10
x60 A150
z-60
Drilling command format
G198/G199 G_ X_ Z_ R_ D_ Q_ P_ L_ F_ E_;
peck drilling example
G0 X0 Z10
G198 G83 X0 Z-30 Q-5 F0.15;
of this example I doubt because never has functioned,because the books are in English and I doubt of the traduccion that I do.
It writes as programs your these same examples to see if there is some variacion.
Old 07-13-2009, 01:32 PM
Sorry for the late reply.
I have never programmed an angle with “A” before. I see that you have X,Z moves in the same line. Is there any alarms with that code? If not can you program your angles by moving the 2 axis?
I am not sure about the G198/G199. Try programming without them. Just remove the G198. Also try putting in a “R” value. This is your start position before feeding. I usually set mine to .1”. Is Q your pick? Is it suppose to be negative? I have never set my pick negative in the canned cycle.
G0 X0 Z10
G83Z-30 R.1 Q-5 F0.15;
Stevo
Old 07-13-2009, 02:44 PM
Hi,i have another two fanuc controls,and the funtion of angle is the same
G00 X20 Z3
G01 X25 Z-1.5
Z-20
X30 A150
Z-40 A90
This example run,but in the hitachi not run, is a fanuc control serie 180.
Whith the drilling i am not sure for the programation,never I have arrived has to run,Q is depth of cut.
How do you write the cycle for drilling G83 in the control of your Hitachi?
I try your example and i spoke you if has functioned.
Old 07-13-2009, 03:19 PM
I am not sure about the angle. I will have to do some reading up on that. Or if anyone wants to chime in and enlighten us. Most of my experience with Hitachi is on mills.
As to the drilling yes the Q is the depth of cut during a pick. The Z is still the final depth. I also see that you have no “R” but you are doing a standard pick with the G83 cycle. You should have a R to specify the return amount after each pick. I have never run a G83 with no R. If you were highspeed peck drilling then the return amount after each pick is usually controlled via parameters. Try the code below.
G0 X0 Z10
G83Z-30 R1 Q5 F0.15;
Should take you to a depth of 30 and pick every 5 to a return amount of 1 at a feed of .15. You can also put in a G98 as to return to initial plane(10) when complete. I have my controls default to G99 so I usually forget to specify that when explaining as I am not use to inserting that in the program.
Stevo
Old 07-15-2009, 02:28 PM
Itry the programation and don´t work
  #11   Ban this user!
Old 07-15-2009, 02:42 PM
So it still gives you the same alarm "NC alarm [191] Option command G80N Whith cycle for drilling" when you try to run the G83 cycle as I had suggested?
I sent you a PM with address per request.
Stevo
  #12   Ban this user!
Old 08-19-2011, 05:01 PM
Maintguy is on a distinguished road
Is it possible that you're machine doesn't have the can cycle option. I'm having a simular issue. My Hitachi Seiki HT 40 G (lathe) recently died, literally lost all param, sub prog, geo, grid position. Had to replace communication card that links the Fanuc drives to the Hitachi control. Now I'm trying to restore my machine and I'm getting the same NC Alarm [191]. Best I can tell, I need to reload the options onto the fanuc side, which requires info that I'm not privy to.
Problem Hitachi Seiki HTG 40 rpt973 General Metalwork Discussion 0 07-07-2009 04:37 PM
Need Help!- Hitachi Seiki HT-20 Threading problem wiks General Metalwork Discussion 6 10-14-2008 01:18 PM
Fanuc 6MB Problem on a Hitachi Seiki VA-50 bachlewelding Fanuc 5 05-04-2008 06:21 AM
Hitachi seiki vm 40 lsbus problem bosko Europe Club House 0 12-30-2007 11:27 AM
ATC problem with Hitachi Seiki VA35 andy.f General Metal Working Machines 0 12-04-2007 01:09 AM
