Old 06-30-2009, 12:41 PM
mmiranda is on a distinguished road
machining plastic
Anyone have an idea on chip control while machining Delrin? Part has 3" plus turned length and we are doing on Citizen. Birdnest of chips has been nearly impossible to clear out. Ideas please.
Thank you,
Mike
Old 06-30-2009, 05:21 PM
judleroy's Avatar
judleroy is on a distinguished road
You can pull the material away from the part while its cutting like pulling a string. Make sure you dont wrap it around your fingers
just grab the end as it starts cutting and pull it away above the cutter if you can so it doesnt start to wrap around the part.
Old 06-30-2009, 05:33 PM
John Welden is on a distinguished road
You can pulse the feed and get the chip to break.
Old 07-01-2009, 09:57 AM
extanker59's Avatar
extanker59 is on a distinguished road
Plastic on a swiss. I've only done it a few times in the past (previous job).
I seem to recall moving the tool away in X, moving the part out in Z to get the chips further into the work area, moving back down to close to the X, and then feeding fast in Z to push the ball of chips off.
Worth a try?
Old 07-01-2009, 10:00 AM
extanker59's Avatar
Oh yeah, I forgot. Aim one or more of the coolant nozzles to try to get the chips off. We did that too.
Old 07-02-2009, 10:03 PM
recordist is on a distinguished road
Plastic Chips
Peck so the strings break, and use lots of air rather than coolant.
Strings are just going to bind, get hot, and make an ugly hole.
Old 07-03-2009, 04:02 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
I read a good reply to a similar thread the other day (I think the poster was HuFlung)- he had the neat idea of putting a slot down the whole length of the bar- that way the string can't form cos it always gets broken as you cut past the slot.Neat idea, but haven't tried myself yet.
I love deadlines- I like the whooshing sound they make as they fly by.
Old 07-03-2009, 09:13 AM
Steve Seebold's Avatar
Steve Seebold is on a distinguished road
Need Help!- machining plastic
There was an article in the June issue of Modern Machine Shop about this very thing. The people in the article used high perssure coolant to blow the chips away.
Old 07-04-2009, 10:42 AM
djr76's Avatar
djr76 is on a distinguished road
Delrin (Acetal) should break fairly easy, the faster you feed it, the easier it should chip. I machine Delrin on a daily basis using a Kennametal WNGP-K insert.
Teflon Plastic lathe machining JPB Mini Lathe 2 10-22-2007 11:39 AM
Work Anyone ? - Machining Plastic Boxes bcdaus Australia, New Zealand Club house 1 07-23-2007 07:18 AM
Machining Plastic (Centriboard) what bit to use? abelloise Glass, Plastic and Stone 1 07-08-2007 11:01 PM
Machining Plastic (HDPE) Buzz9075 Glass, Plastic and Stone 11 07-01-2007 06:45 PM
Machining engineered plastic skykash2000 Test Forum 0 09-18-2005 08:34 AM
