Old 06-29-2009, 02:18 PM
coolantman's Avatar
coolantman is on a distinguished road
Price
can anyone tell me what the cost for a drum of blasocut2000 univ typically runs?
thanks in advance
Old 06-29-2009, 08:39 PM
paul gibson is on a distinguished road
Sorry can't tell you about a drum price, but locally I gave 126.00 in May for the last 5 gallon concentrate I purchased. Good stuff, but is getting higher each purchase.
Paul
Old 06-30-2009, 03:26 PM
coolantman's Avatar
Thanks Paul!!
Do you think there is a price break for 55 gallon drums?
Old 07-01-2009, 03:52 AM
I am almost sure there would be. The only thing that may offset a cost break woud be shipping cost on the heavier container.
p.g.
Old 07-02-2009, 02:37 AM
Delw is on a distinguished road
not that much of a price break, it used to be a good chunk of change but recently( last year or 2) 55 gal barrel prices went up.
I think you would save maybe 200 bucks if you buy it local.
we looked at buying a 55 gal drum of qcut 250 and it was around 1200 I believe
however dont look at it that way look at it this way and you will save more.
get a automixing valve that the hose screws on directly to the valve and plugs into the barrel. you will save probably 10 gallons of coolant concentrate this way.
when we mix it by hand we tend to over do it, so every time you mix it you add to much. with a auto mixing valve and the right orfice size you can always add the correct amount to keep your adjustment corrected for evaperation.
there used to be about a 1/3 savings from buying a drum to 11 buckets, not anymore
in the long run your going to save money, plus save time from mixing which all adds up.
Delw
How Not To Price Geof General Business Practices and Pricing 6 08-11-2008 12:55 AM
Trying to get price gio666 CNCzone Club House 1 05-07-2008 01:46 PM
Price on KX3 cnc in the USA? squale Benchtop Machines 32 04-24-2008 08:20 AM
price manuelc149 Mastercam 9 09-13-2007 10:13 AM
The Price is Right? Epik General Metalwork Discussion 2 03-02-2005 02:39 PM
