Old 06-22-2009, 08:24 PM
Cartierusm is on a distinguished road
4th Axis Set Up
So I'm building a 4th Axis from a new Harbor Freight 9x20 Lathe Head with a 2.865 Pitch Gear Pulley and using a 570 oz/in. Stepper with a 1.194" Pitch Gear Pulley.
As far as alignment I take it just put it on the mill and with a nice straight rod in the 4th axis chuck use a dial indicator in the mill chuck to go along the centerline on the side until its good?
I was also thinking of mounting the 4th axis to an aluminum plate (faced of course) and using dowels and liner so setup after the first time would be a breeze. Would this be accurate enough? Thanks.
Old 06-23-2009, 09:07 AM
John Welden is on a distinguished road
Sure you can dowel it on.
It's better to indicate a surface that is perpendicular to the bore. That may be the nose/face or another ground surface. The problem with indicating a rod is that you don't know if it's in there perfect.
Old 06-23-2009, 12:55 PM
So if the 4th axis is being used vertically I could just traverse the face of the chuck? That sounds easier.
Then whats the best way to find the centerline after lining up the 4th axis.
the Difference of 2-Axis and 3-Axis of Vertical Mill Machine begacon Knee Vertical Mills 6 07-30-2009 06:31 AM
New Machine Build- post for 2 axis ez trak versus 3 axis ez vision tooolman G-Code Programing 0 11-28-2008 03:33 PM
Compare Catia and MCX2 for multi axis lathe/4 axis mill bob1112 General CAM Discussion 0 10-10-2008 07:15 PM
How can I coupling a stepper motor axis directly to other axis? meknik2001 Stepper Motors and Drives 4 05-08-2008 01:54 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
