Old 06-15-2009, 03:18 PM
maz43's Avatar
maz43 is on a distinguished road
Thin walled part
I will be making some RC boat rudders out of 6061 Aluminum in the near future.
The part is 6" long and 1.15 front to back. The wall is .12 thick in the front and .010 thick in back(3 degrees per side). Any ideas how to get a good finish on such a thin part?
I was thinking of leaving extra stock lengthwise and clamping both ends in a fixture for the 1st side, then flipping the part lengthwise and bolting a 3 degree shim to the fixture to support underneath for the last cut.
I have not had to mill anything this flimsy before and any suggestions are welcome.
Thanks,Maz
Old 06-15-2009, 04:51 PM
John Welden is on a distinguished road
Do you have CNC?
You can mill the whole part from a solid block. Work from the thin end down. Mill a little on one side and then do the same thing on the other until you work your way all the way down.
The idea is that the extra stock supports the piece as you cut your way down.
There is a million ways to do it depending on the tools that you've go.
Would be nice to see a model/drawing of the part.
Need Help!- Turning a Thin part and Getting a Bad taper JWB_Machining General Metalwork Discussion 4 02-26-2009 09:26 PM
Newbie- thin workholding tonyaimer Tormach PCNC 13 09-25-2008 02:47 PM
cutting thin metal clittle Opensource Forum Rules 3 09-05-2007 04:27 PM
Cutting thin aluminum neonguy CNC Plasma and Waterjet Machines 2 10-13-2006 08:29 AM
Thin sheet metal itsme Welding, Brazing, Soldering, Sealing 9 03-01-2005 03:24 PM
