EnviroServe Chemicals has developed a new type of sump cleaner for metalworking machines. Sump Cleaner III is a concentrated on-line sump tank cleaner that is designed to be used without interrupting the machining process. When used properly, this cleaner should be added to the tank 2-3 days prior to dumping the coolant. This cleaner effectively loosens deposits of degraded coolants, oil, chips, and sludge from the sump, inside the machine, the coolant lines, and the nozzles. Sump Cleaner III is recommended to be used at 1-3%. This product can also be added periodically to control bad odors. Keeping you machine clean and safe to work with is very important to your health. Keeping bacteria to a minimun is a key when producing a good machined product. Call for more information -Coolantman EnviroServe Chemicals, Inc. (910) 892-1791 |
| Problem- sump stink tried only one that works | hwcare1 | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 04-10-2009 10:56 AM |
| Need Help!- chips in coolant sump | gromit68 | Haas Mills | 3 | 06-26-2008 08:28 AM |
| Need Help!- Old Vacuum Cleaner | Drakkn | DIY-CNC Router Table Machines | 2 | 05-06-2008 10:36 PM |
| Window cleaner as cutting fluid | voxelman | General Metalwork Discussion | 12 | 05-14-2006 01:03 AM |
| Cleaning out the sump, what a mess | KSky | Bridgeport and Hardinge Mills | 2 | 09-13-2005 04:28 PM |
