Old 06-04-2009, 11:02 AM
kwmkoester is on a distinguished road
-AN/ 37 degree inverted Flare milling cutter
Does anyone know where I can buy a form cutter for pre-milling a 37 degree inverted flare in a brass manifold. It's essentially the male version of where a 3/16 flared brake line would thread into and seal, it's a threaded bore with an inverted flare at the bottom. I need a cutter ASAP and if anyone of you could help me I would be very thankful.
Problem- T SLOT MILLING CUTTER PACKAGE 5 (ON WALTER CNC CUTTER GRINDER) dharschman Toolgrinding & Toolgrinding Machines 3 09-13-2010 12:25 PM
Need Help!- Insert Milling Cutter Repair? gepperta General Metalwork Discussion 0 05-05-2009 02:15 PM
Milling cutter comp j44snk Okuma 6 01-14-2009 03:56 PM
In one year I will gradeuate with an industrial management degree.WTF is this degree? KyleH2 CNCzone Club House 3 06-29-2008 07:30 PM
Milling 37 degree chamfer around a circular piece... peter.blais General Metalwork Discussion 21 09-20-2006 12:47 PM
