The first one I broke at 12,000 RPM @ 1in/sec and the second was at 12,000 RPM @ .3in/sec. I'm cutting .062 6061 plate. Can someone recommend the correct feed & speed before I break any more of them experimenting? ![]() (I forgot to mention that the pass depth was 0.0156) Thanks all! g. Last edited by geneb; 05-30-2009 at 04:55 PM. |
| How long is the .062 diameter length of the tool? How many flutes? How deep are you cutting per pass? |
| What kind of machine? Any coolant/lubricant? Do you mean in/sec or in/min?
__________________ "Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away." Antoine de Saint-Exupery (1900 - 1944) |
| Hoss
__________________ http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com |
Regards, Ray L. |
| I've been running 1/16" em's at 3 IPM with a plunge of 2 IPM. I run 3/64" em's at 1.2 IPM with a plunge of 1 IPM. Both are carbide 2 flute cutting 6061 on an X2 with flood coolant. I haven't broken a bit in a long time now and I've only got ~4600 RPM. Takes quite a while to get the job done but the details look very good. HTH Oh yeah, DOC for the 1/16" is 0.02" and for the 3/64" is 0.01" |
#10
| I cut that same material on my mill. I was using a trim router mounted on it, but now that I have upped my spindle speed to 6600 RPM, I get good results with a 3/16" 4 flute EM. I go .025" depth at 30 IPM @ 6600 RPM. I was using a 1/4" bit in my trim router. My mill is set up to run automatically though, so I prefer to use it now. Here is a video of the way did it with my trim router. Turn the sound down. ![]()
__________________ Lee |
#11
| Very nice Lee. I just discovered that my 'bot has a "default" slowest speed of .5in/sec. I'll need to change that before I run the file again.I needed to use the 1/16" bit because of some very small features on the part - it's the mounting plate for the IFF panel in my F-15C flight simulator (http://www.f15sim.com) Now that I know what's going on, I won't snap any more tiny cutters. ![]() I'm tempted to use the 1/32" cutter I have if I can get the 'bot slowed down enough. ![]() g. |
#12
| With the tiny cutters, you really have to go slow. I use 1/8" cutters on 6061 bar stock and it works great. I rarely ever break an EM. I do use a feedrate of 25 IPM on those @ 6600 RPM with .02 DOC. Coolant is a must going like this though.Otherwise the flutes will clog. Using a router, you can get away with spraying WD40 on the part. Keep the DOC and feedrate down and you should have no breakage.
| "Gol-Matic" mills; interesting setup | Swede | General Metal Working Machines | 17 | 09-23-2009 07:35 PM |
| Retrofit Lucas Horizontal Boring Mills...5" and 6" | Banzai11 | Mach Mill | 0 | 06-17-2008 10:32 PM |
| "Off the Shelf" Benchtop CNC Mills | jeffo2001 | Benchtop Machines | 29 | 03-06-2008 07:44 AM |
| Looking for "trusted" names in the Industry for CNC mills. | l u k e | General Metalwork Discussion | 28 | 07-06-2007 04:42 PM |
| New "Universal" type mills? | clockmaker | General Metal Working Machines | 1 | 08-09-2004 12:02 PM |
