Hi we would be starting a research & development project for medical stuff and it will made from Titanium, i hope you can share to me some speed & feed & depth of cut chart for cnc milling operations |
Call your supplier!
__________________ All comments made are my opinion! |
| We don't do production so these speeds and feeds may be slow. 150 sfm and .0002-.002 ipm for carbide endmills (from 1/16 to 1/2") 35 sfm for cobalt drills Keep in mind that medical parts are weird shapes and on secondary ops you rarely have much to hold on to. I was actually hoping to see some speeds and feeds from a production guy but these work. |
| Simple rule: *** This is for prototyping, not mass production*** Treat it like 304 Stainless Steel, DO NOT cut dry, avoid slow feedrates. Tapping holes isn't fun. There was a post on CNC Zone about tapping holes and a suggestion for using a specific brand of tap that worked well for Ti. Try a search for Ti tapping. TM Oh...I didn't see the post above, that's sounds good. Last edited by Tomorrow_man; 05-30-2009 at 07:45 AM. Reason: forgot to read |
| thanks again, yes your right they are weird shape, seen some drawings last friday and the problem would be how to hold on the second operation, and there would be a 2mm tap holes on it. for the mean time we would be doing prototype but i guess if finalized with the design they might go on to production unless they sent it in china, and for now i will treat machining it as stainless, been reading some articles from Boeing team on how they machine Ti. |
| Hi, Machining Titanium is a bit tricky job. If possible, go for wire-edm. Or follow good-ole tips. Sharp tools, not too light cuts & rigid clamping. Titan Engineering http://www.titanengg.com.sg
__________________ Titan Engineering, Singapore. Titanium Metal & Alloy suppliers. |
| Newbie to CNC aluminum milling feed/speed/depth/coolant, etc. | mrk | General Material Machining Solutions | 4 | 03-30-2009 01:51 PM |
| Balancing Speed, Feed, and Depth of cut on underpowered machines | jmlarson | General Metalwork Discussion | 7 | 02-10-2008 07:18 PM |
| Optimizing Milling - Speed, Feed & Depth of Cut | palikalsi | General Metalwork Discussion | 5 | 04-03-2007 04:59 PM |
| Where's the Lathe Speed, Feed, and Depth Data?? | Otokoyama | General Metal Working Machines | 4 | 02-06-2006 01:14 PM |
| feed, speed and depth of cut for 1/16" carbide EM in brass | balsaman | General Metalwork Discussion | 9 | 09-26-2005 02:40 PM |
