Old 05-28-2009, 11:09 AM
mattpatt is on a distinguished road
Milling SKD11 steel
Hoping you may be able to offer some assistance.
Gotta cut some SKD11 and would like some recommendations on cutting speeds, feeds etc.
Main issue is some 8mm wide slots, 9mm deep. Open entry, so no plunging required. I'm thinking a 6mm 4F 1R carbide bullnose.
The above tool is the main issue as it's the only one taking a full diameter cut.
Any help greatly appreciated.
Matt.
Old 05-29-2009, 09:19 PM
PixMan is on a distinguished road
From my cross-reference material, it seems to be a hot-work mold steel, not far from what we in the U.S.A. refer to as H13.
What condition is the material in terms of heat treat/hardness?
Old 06-05-2009, 02:44 AM
Hi PixMan,
Sorry for the delay in replying.
Don't know the exact spec of material. Less than 40 HRC I've been told.
Been playing with trochoidal milling recently in some 6061 T6 and having fun, so was thinking that I'd like to give this a go if it's recommended.
Do you think I could go the full DOC (9mm - finish) with a carbide TiAlN 6mm 4F endmill?
Going from this tool spec sheet I'm looking at 5800rpm, 0.03mm/tooth, 0.15mm stepover.
I'll be having a go at this tonight, so I'll see how it goes.
Let me know if you think it'll all end in disaster! :-)
Thanks,
Matt.
Need help on milling steel DaOne General Metalwork Discussion 19 12-19-2008 08:11 AM
Milling 420 Stainless Steel Talisman General Metalwork Discussion 4 12-06-2008 12:57 PM
Need Help!- Milling 4130 Steel JWB_Machining General Metalwork Discussion 3 11-06-2008 11:04 AM
Milling a peice of steel dneisler General Metalwork Discussion 2 06-20-2008 02:44 PM
bending of steel after milling dhiruj General Metalwork Discussion 17 03-23-2007 02:29 PM
