Old 05-25-2009, 03:07 PM
Cartierusm is on a distinguished road
Knurling on a CNC lathe?
How do I knurl on a CNC lathe. I'm using Dolphin and the program doesn't have a specific function for it. Any help would be appreciated, thanks.
Old 05-25-2009, 06:27 PM
PixMan is on a distinguished road
Like you would on any manual lathe, just use G codes instead of hand pressure.
That said, you should be using a rather rigid knurling tool, definitely not a floating type such as an Armstrong meant for manual lathes. Check with the website for Form Roll Die or Accu Die (the owners of both are feuding brothers.) There's a wealth of knowledge between them, and all the right tools.
What kind of CNC lathe are we talking about here, and what kind/pitch of knurl on what material?
You would program the tool to come in pretty fast, and feed across quickly too. It'll take a little trial & error to get a good knurl, but read up as much as you can first.
Old 06-14-2009, 11:29 PM
madonno is on a distinguished road
We use knurling tools on machines with a physical Y-axis so we found it way faster and easier to align the knurling tool by just using the Y-axis instead of manually adjusting the wheels (centerheight).
New Lathe - Excessive Knurling Pressure - Then POP! widgitmaster General Metal Working Machines 25 04-04-2009 11:30 AM
Knurling with V9 DublJ Mastercam 1 01-04-2008 08:31 PM
Knurling gr8life General Metal Working Machines 1 10-31-2007 05:02 AM
knurling SAWMAN General Metalwork Discussion 14 03-16-2007 09:50 PM
Knurling ? Ken_Shea General Metalwork Discussion 13 02-23-2004 10:17 AM
