Old 05-23-2009, 09:00 AM
LatheCrasher is on a distinguished road
Spur Gear indexing
I need to machine a spur gear with 106 teeth. I'm not having a problem calculating diametral pitch, addendum, etc. nor figuring what pitch cutter to use. My problem is with the indexing calculations. I'm using B & S plates with 40:1 ratio. Per the machinists handbook, 106 target divisions require 1 full turn plus 7 holes on 39-hole circle + 29 holes on 41- hole circle. I know 40:1 means that 1 full rev of the indexing head = 9 degs and no probem calculating up to 40 divisions. The number of divisions over 40 requiring partial turns is confusing me. Could someone break it down step by step?
Thanks!
Old 05-23-2009, 09:48 AM
Try this: http://www.atmsite.org/contrib/JSAPP...e/divhead.html
Dick Z
DZASTR
Old 05-24-2009, 08:15 AM
Thanks for the link. I can do the easy ones, I wish he had given an example of compound indexing like the one I'm working.
Old 05-24-2009, 10:23 AM
Compound indexing?
Dick Z
DZASTR
Old 05-24-2009, 04:09 PM
Kiwi is on a distinguished road
The nearest with a 40:1 Ratio and std plates.
Use 16 holes circle and rotate 6 holes.
This will be 4 holes short at the end so suggest you advance 1 hole at tooth 26,53,79,106.
Old 05-24-2009, 07:31 PM
Superman's Avatar
Superman is on a distinguished road
I'm confused, 106T
If one turn = 9°
& 40 turns = 360°
If I cut at eact turn, I would get 40 teeth ( correct )
then
How many teeth do I get at 1 full turn plus 7 holes on 39-hole circle + 29 holes on 41- hole circle.????? ,,,my guess is something less than 40 teeth
my calc is 40/106 = 20/53 = 20 holes on a 53 hole plate just over 1/3 of a rev.
here's a link page 105
Old 05-25-2009, 02:55 AM
Looks like 21.2 teeth.
If this 21.2 cycle is repeated 5 times this gives 106.
Not sure how this works and if all the teeth are evenly spaced?
Old 05-25-2009, 10:06 AM
That is the way I calculated it Superman. I'm using Brown and Sharpe standard plates with no 53-hole circle. I see in the Machinist's Handbook that Cincinnati plates have a 53-hole circle. Sorry for the confusion but I got my info that I posted from the Machinist's Handbook from the "Simple and Compound Indexing with Brown and Sharpe Plates" chart found in the Milling Machine Indexing chapter. I guessed that 106 target divisions would be the same as "106 teeth."
Old 05-26-2009, 05:10 AM
Superman's Avatar
Finally found what you need - bad news is..... it's a Cincinnati
But it has how it is calculated PAGE 214
http://books.google.com/books?id=dhX...um=7#PPA214,M1
If the link doesn't work, r-click on it, properties, copy the "Address URL" section, and paste into the address bar
Old 05-26-2009, 07:08 AM
Here is a good article on Compound Indexing. Also a chart of the Index Movements. Page 143 on.
http://books.google.co.nz/books?id=N...um=9#PPA143,M1
  #11   Ban this user!
Old 05-26-2009, 07:22 AM
Charles Lessig is on a distinguished road
I posted this before but it is pretty simple.
If you don't have a 53 space circle, print
one out on paper and stick it to a plate and move
your index pin and sector arms by eye.
Any error is reduced by 40 to 1 through your gearing.
Keep going in the same direction to avoid back-lash and
if you do over-shoot, back up some and try again.
Clamp the head while cutting and have no distractions
at all.
Best Regards, Charlie
Old 05-26-2009, 08:06 AM
HuFlungDung's Avatar
Moderator
...have no distractions at all.
I'm not clear on how you do this last part
Making a four stage spur gear box? (how to ) youthreewire Mechanical Calculations/Engineering Design 14 02-26-2009 09:11 PM
..the teeth on a pinnion spur gear... malJohann Mechanical Calculations/Engineering Design 4 07-13-2008 04:22 PM
Simple spur gear design wildcat General Metalwork Discussion 9 05-23-2008 06:17 AM
Spur gear availability? 2fst4u CNC Plasma and Waterjet Machines 3 04-02-2007 08:46 AM
Spur Gear / Gear Rack ckrantz Linear and Rotary Motion 12 12-06-2006 11:06 PM
