Results 1 to 2 of 2
Thread: How do I fit a coolant adapter??
    Jul 2006
    uk
    I have just purchased a Lyndex B30CM-CCT3/4A-165-65 coolant holder for my Bridgeport R2E3 vertical mill. Can anyone give me some idea how this is attached. The BT30 fitting is straight forward but it appears to require some form of Solenoid to allow it to turn?
    Steve[FONT= Book Antiqua]Steve[/FONT]
    Apr 2009
    Thailand
    I'm not sure what the holder's look like, also not have a picture to see.
    In my experience the coolant holder adaptor that allow coolant go in "thru hole of cutting tools" need some modification on spindle.
    It use a machanical lock. you need to make a stopper block attach to spindle when put this holder in to machine spindle taper. This stopper will push the lock down and free the gear in side, after that the tool can be rotate
    If you wish to use this holder in tool change, it need to make sure the dimension can fit in tool pocket.
    Also the stopper block need to place in right positin of tool change.
    Can you sent me you tool holder picture or link to e-catalog of this tool holder, than I can more clearly understand and explain how it work ?
  1. Need Help!- NMTB 30 to R8 Adapter
    By Jeff Chandler in forum General Metal Working Machines
    Last Post: 01-09-2009, 11:51 PM
  2. PC-MPI ADAPTER
    By CHANDRU in forum General Electronics Discussion
    Last Post: 12-14-2007, 06:06 AM
  3. Int 30 Coolant adapter
    By s1j1m10 in forum Bridgeport and Hardinge Mills
    Last Post: 08-09-2007, 09:28 AM
  4. 3/8 to 1/2 adapter
    By TMaster in forum Benchtop Machines
    Last Post: 07-29-2006, 07:15 AM
  5. collet adapter
    By truman in forum General Metalwork Discussion
    Last Post: 03-24-2006, 09:43 PM
