Old 05-20-2009, 07:46 AM
BILLYD is on a distinguished road
INTERNAL GROOVING
I am trying to machine an internal groove in steel. I can't seem to get from the customer what exactly the steel is, but it is not hard and is very gummy.
The problem is that I am going into a .260 hole with a solid carbide groove tool with a .250 minimum bore size. The groove is .460 deep and the tool is made for a .500 deep max. hole. It is 3/32 wide. I have tried numerous feeds and speeds but I keep breaking tools. The chips build up on the tool no matter what I try. Any suggestions would be appreciated.
Old 05-20-2009, 08:10 AM
Jason S is on a distinguished road
Break your depths into increments. Go .03 deep or so, retract out of part so the chips can be flushed out. Repeat until you get to the desired depth.
DANGER ZONE - HARD HAT REQUIRED!!!!
Old 05-20-2009, 11:01 AM
extanker59's Avatar
extanker59 is on a distinguished road
It sounds like it could be CMI, a steel used for magnetic solenoids (redundant?).
IF it is, then high SFM and low feeds with very sharp tools AND follow Jason's recommendations.
Old 05-20-2009, 06:43 PM
g-codeguy is on a distinguished road
As you have already found out one of your biggest problems is going to be chips packing in the hole. I have a similar job (little bigger diameter, but no place for the chips to go cause I'm also using a bigger tool). I peck groove a ways, re-drill, peck groove, re-drill, peck groove, re-drill...well you get the idea.
Need Help!- Grooving HELP! modeltruckshop@ General Metal Working Machines 4 04-22-2009 08:49 PM
od/face grooving bala955 Surfcam 1 01-30-2009 09:50 AM
Grooving an internal bore roady89 Bridgeport and Hardinge Mills 2 08-28-2008 01:09 PM
deep grooving eject_21 G-Code Programing 3 06-15-2007 12:59 AM
What is the G code for Grooving? Not G75? cjchands Mach Software (ArtSoft software) 7 04-22-2007 05:07 PM
