Old 01-28-2005, 01:07 PM
*Registered User*
ChrisJ is on a distinguished road
Vertical/Horizontal Bandsaw purchase
Looking to purchase a V/H bandsaw, probably in the 7x12 capacity. Would like to poll anyone who cuts their own stock, what you are using and ask for your experience on what features to look for (geared versus belt drive, etc.) Which features are worth spending the money for?
Old 07-21-2007, 05:23 AM
bjk1903 is on a distinguished road
Did you try the best Turkish Manufacturer's machine for Bandsaw UZAY MAKINA. www.uzaymak.com
Old 07-21-2007, 07:16 AM
Skeeterd5150 is on a distinguished road
http://hyd-mech.com look up the dm 10. We have a large one in our shop and it is like they say "rock solid".
Old 07-21-2007, 08:30 AM
I have three different makes in my shop and the hyd-mech is the most convenient to use.
This one has the rotating head for cutting angles so the length of material always stays straight along the feed rollers.
It can cut past 45 degrees which is sometimes handy.
It has a very solid vise.
The controls are fairly user friendly; everything is grouped conveniently.
My suggestion is to find a dealer with different makes set up and running so you can try the controls. Some makes you have to do two or three operations to start every cut, on the hyd-mech once things are set you just pull a trigger for repeat cuts.
Looking to Purchase CNC Mill/Drill, which one? mtuckf Benchtop Machines 3 04-11-2005 08:39 PM
want to purchase a CNC from anyone corbyvhall Benchtop Machines 1 03-24-2005 07:08 PM
What to Purchase Robin General Metalwork Discussion 3 02-28-2005 06:53 AM
Bandsaw accuracy? gtslabs General Metalwork Discussion 3 12-29-2003 09:26 PM
Can you cut Al. with a wood bandsaw CactusChip General Metalwork Discussion 5 11-20-2003 03:45 PM
