Page 1 of 2 12 LastLast
Results 1 to 12 of 17
Thread: 3/8" shank tooling - face mill
    Jan 2007
    Does anyone know of a face mill with a 3/8" shank? Looking through the rutland tool catalog I don't find anything. I have a machine with an ER16 spindle so 3/8" is the largest shank I can use. I'm looking for maybe a 1" or so face mill for it.
    Registered marcel beaudry's Avatar
    Sep 2005
    canada
    K A R catalog page a168
    Marcel Beaudry
    Jan 2007
    I looked. That's a 3/8" shank but also a 3/8" cutting diameter. I'm looking for something with at least a 3/4" cutting diameter but a 3/8" shank.
    May 2006
    united states
    You may have to look at fly cutters instead of face mills if you want to cover that area with that small of a shank.
    Jan 2007
    Are you aware of any flycutters with 3/8" shanks?
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    Post
    Here you go.
    http://grizzly.com/products/H7537
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Sep 2005
    canada
    Hello Travis
    A small collet , it will have to be a small fly cutter i do not know if your machine as enough power for a large fly cutter.
    Marcel
    Registered mc-motorsports's Avatar
    Feb 2007
    Just buy a facemill, will probably have a 1/2" shank on a 1" diameter cutter using 2 carbide inserts, put it in a conventional lathe between centers (most facemills are turned between centers and will already have centering spots), turn it down to 3/8".
    MC
    Jan 2007
    MC, thanks, that's the best suggestion I've heard. And too obvious. Aren't the shafts on most tooling hardened though?
    Jan 2007
    Jalessi, thanks, I hadn't seen those.
    Moderator tobyaxis's Avatar
    Jan 2006
    I suggest taking a look at Seco Nano Mills
    http://www.secotools.com/wps/portal/corp
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Feb 2007
    Quote Originally Posted by TravisR100 View Post
    It's not going to be over 40rC, if even close to that. Cutting tools, yes, tool holders, not so much. You can lathe turn it with carbide no problem.
    MC
  • Page 1 of 2 12 LastLast
    1. Newbie- 8" Face mill on a series 1 bridgeport
      By wrechin2 in forum General Metalwork Discussion
      Last Post: 01-05-2009, 01:08 AM
    2. 1/8" shank endmill holder
      By CNCMike in forum General Metalwork Discussion
      Last Post: 10-23-2008, 11:58 PM
    3. Best tooling for 1/2" profiles on a micro mill?
      By sansbury in forum Benchtop Machines
      Last Post: 02-25-2008, 12:07 AM
    4. HF Micro Mill - R8 Shank Tooling
      By jeffo2001 in forum Benchtop Machines
      Last Post: 06-28-2007, 08:07 AM
    5. 3" Face Mill in a Seiki 4VS?
      By TZ250 in forum Vertical Mill, Lathe Project Log
      Last Post: 11-01-2006, 12:18 PM
