WE MACHINE A TON OF PARTS ON THE LATHE THAT GET A 1/4-18 NPT FEMALE PIPE THREAD IN 5/8 316 SST HEX. (CNC LATHE) HAVING TROUBLE GETTING INSERT LIFE. WHAT ABOUT USING A TAP. ANY HELP? BAD DOG |
| Good luck with that, friend! We have basically given up on that size thread in that material. Cost is too high. We tap as a secondary.I certainly would like to know if you do find a combination of insert, RPM. DOC, etc. that does work. Bet plenty of other inquiring minds would like to know also. |
| Have you tried these? Besly spiral Dormer also makes some Don't know if it would help to cut the hole tapered before tapping so the tap has less to remove. I have heard that these help retain tapping oil like sulpher based cutting oils to prevent material buildup. Might be worth a try in high production where the increased through put pays off better than single pointing. DC
__________________ Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade. |
| BAD DOG In our (my son and I) business we manufacture marine hardware and use a lot of 316l S/S and tap a lot of fuel and oil manifolds. We have found the best way, is to drill and taper reamer for the NPT size and use stagger tooth taps with a high Sulfer base cutting oil, you need the sulfer for lubricaton since 316 has more soft Nickel and will gall. If I was doing it on a CNC Lathe I would drill base hole and then run a NPT taper reamer then single point the hole. It also helps if you ream to the max pitch diameter. Bob |
I prefer to single point anytime I can. Only problem single pointing a 1/4 NPT is there is no place for the chips to go. Inserts won't hold up. I assume you mean max bore. |
| If you got the skills grind a little more relief on the backside of the tip of the insert try around 15 to 20 deg. I had chip clearance issuses and that helped. Also try .002 to .003 D.O.C. per pass. And if you can richen up your coolant to 20% |
| If using the full-form inserts as I suggested, grinding a relief is not possible nor advisable. The only adjustment is the shim seat under the insert which must be matched to the lead angle of the thread. The smaller boring bars and external threading tool holders may not have the interchangeable shim seats, but their smaller inserts are thinner and made with the side reliefs at high enough angles to handle almost any thread lead angle. (The lead angle increases as the diameter shrinks if given the same number of threads per inch/mm.) |
| Four Carriages on Two 15mm Rails or a Single Carriage on a Single 45mm Rail ??? | joprinz | Linear and Rotary Motion | 12 | 10-07-2008 06:08 AM |
| ID Threads | phoodieman | Daewoo/Doosan | 27 | 01-03-2008 08:33 PM |
| New threads that are not new??? | turmite | Forum Questions or Problems | 1 | 01-27-2005 08:52 AM |
| npt threads | scubasteve | G-Code Programing | 13 | 03-16-2004 04:37 PM |
| Saving threads or parts of threads??? | flybynight | Forum Questions or Problems | 4 | 02-22-2004 12:19 AM |
