Results 1 to 2 of 2
Thread: New Lathe CNC Feeds and Speed Help.
    Dec 2006
    So I've just converted my Harbor Freight 9x20 Lathe to CNC. I have no idea on feeds and speeds for aluminum.
    What would be a starting point? I'll be converting to a variable speed motor so I should be able to use Constant Surface Speed. So I do I need to set anything else? I have all new good indexable tooling. From what I've gathered from Little Machine Shop I should set in my CAD .004 per revolution and a depth of cut .04". It also says for carbide tooling to use 2820 as the SFPM. Is this a good starting point or is it too slow or too fast or too deep. Thanks.
    May 2007
    I am not familiar with small lathes like this so I can't comment on DOC or feedrate, but I can tell you that I run aluminum at max RPM. If you can run 5000 RPM without vibration, then run it that high.
  1. Long tool. Speed and feeds recommendations
    By G-code in forum General Metalwork Discussion
    Last Post: 06-06-2008, 03:01 PM
  2. Replies: 4
    Last Post: 04-09-2008, 01:51 AM
  3. Problem- BCC v22 Speed/Feeds corrupted if file saved without post
    By brooklynmetal in forum BobCad-Cam
    Last Post: 03-25-2008, 09:33 AM
  4. 3D Profiling EN24T - Speed & Feeds
    By Davidimurray in forum General Metalwork Discussion
    Last Post: 10-12-2007, 07:46 AM
  5. Speed and Feeds problems
    By Tazzer in forum General Metal Working Machines
    Last Post: 09-17-2004, 08:03 AM
