Results 1 to 5 of 5
Thread: For wood in a mill do I bolt a router to side or increase spindle rpm?
    Mar 2009
    I want to mill wood in my X3. I already know that the 2000 rpm it puts out will not give the best results. My question is should I get a timing belt conversion that will give me a lot more rpm or do I get a router and bolt it to the side of the head somehow?
    Registered Bowman's Avatar
    Sep 2004
    I would opt for the router motor mounted to the spindle head versus trying to jack up your spindle speed. Odds are your spindle is only rated for slightly more rpm's than it is designed to run under so trying to overload that speed could fry them quick.
    The router will give you a lot more rpm which is much better for wood cutting and if you look around you can find one that stripped down does not stick out to far loosing you travel distance. You will want it mounted as close to flush to the mill head as possible..
    Good luck..
    Bo
    Mar 2009
    Use a laminate trimmer instead of a full size router.
    Mar 2009
    Quote Originally Posted by John Welden View Post
    So a Full size router is too big? Is a dremel too small?
    Sep 2006
    Quote Originally Posted by slashmaster View Post
    Dremel's have really poor bearings and a lot of runout. They won't last very long.
    I don't see anything horribly wrong with using a full size router. They will definately have enough power at the cost of more weight and noise.
    I am very happy with the Bosch Colt laminate trimmer in my CNC router. It has enough power for my needs and is very quiet. I usually cut at around 1/2 of the max RPM. It comes with a 1/4" collet and you can now get 1/8" collets for it at http://www.precicebits.com
    Steve
    1. Need milling spindle assembly -- not wood router
      By pgruendema in forum Want To Buy...Need help!
      Last Post: 02-08-2008, 10:23 PM
    2. Z-axis - mounting rails on spindle side, rather than tower side
      By guru_florida in forum Linear and Rotary Motion
      Last Post: 01-31-2008, 07:54 PM
    3. Bolt on laser cut to wood router ?
      By xairflyer in forum DIY CNC Router Table Machines
      Last Post: 01-09-2008, 12:14 AM
    4. wood router and spindle control
      By eloid in forum CNC Wood Router Project Log
      Last Post: 02-21-2007, 05:39 PM
    5. Wood router, suitable spindle drive like shopbot?
      By GalaticDan in forum Commercial CNC Wood Routers
      Last Post: 06-09-2005, 12:32 PM
