I was just trying to trim about a 1/16th off some steel. I was cranking just the X wheel and without even touching the Z wheel the endmill was slowly working it's way downwards. I'm guessing the endmill was working it's way out of the chuck. Is this common? What do I do about it? Feed slower? Or just try to tighten the chuck tighter? |
| If I understand correctly,you are using a drill chuck to hold the end mill?If so,it doesn't matter how much you tighten the chuck.The end mill will work it's way out.You should be using the proper size collet.If your machine uses R-8 collets,you need to buy a set.They are not real expensive. |
| You can use the suggestion above or if you want to spend some $$ you can buy an Albrecht Diamond Chuck. It is Ideal for holding carbide tooling, but feeds and speeds will be much lower than a collet (suggested above and better than a drill chuck) and cutting forces will have to be reduced significantly. You better off with a Collet or a Solid Tool Holder (ETM is Iscar). http://www.albrechtchucks.com/tech_i...oated_jaws.cfm http://www.use-enco.com/CGI/INPDFF?P...PARTPG=INLMK32
How will you centralize the tool? Besides that you might have a tough time drilling and tapping through the chuck. I have never done it myself, but I can imagine it is Hardened or Forged. Not very friendly.
| You are missing the point. You should NEVER use an endmill in a chuck. IT'S DANGEROUS! Chucks are only held to the arbor by friction. Side force can loosen the arbor, sending it at YOU. Imagine a whirling sharp endmill ripping your skin. Get yourself some Tormach quick change holders in 1/4, 3/8 and 1/2 and some same shank end mills. Or invest in a collet set. http://littlemachineshop.com/product...itFast=tormach CR. |
#10
| As stated already. Get a set of decent R8 collets. Cheap HF quality drill chucks will not keep the jaws parallel enough to grip an EM shank under side loading cutting steel. They are primarily for axial thrust cutting forces, not radial. For that matter cheap chucks barely hold a drill on center. If it isn't the jaws that fail to grip tip to tail, it will be the taper holding the chuck to the mounting shank that can losen. Either case, yes..it does get ugly when they come untogether at several hundred RPM. I am no fan of the ER-like collet setup you linked to. The more connections you add to a spindle, the worse the runout and lower rigidity. Not to mention the HF quality again. DC
__________________ Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade. |
#11
Trust the other comments and get some collets. You can plunge with a endmill in a drill chuck but thats about it. I guess if it was life or death you could do the set screw mod you're talking about. You could also glue your wheels on your car if you couldn't find any lug nuts. Maybe use coffee as motor oil since its the same color. |
#12
![]() Ya still gotta admire inge-nub-ity and desire. We were there once too Slash. Learn and move on! DC
| Does the company you work for sharpen their own endmills & drills? | widgitmaster | Polls | 29 | 04-04-2010 05:49 AM |
| Typical color code of stepper motors | abasir | Stepper Motors and Drives | 0 | 05-29-2005 09:19 PM |
| Parts list for a typical controller setup | bgolash | Gecko Drives | 1 | 09-20-2004 08:20 AM |
| Typical power supply | ynneb | DIY-CNC Router Table Machines | 0 | 04-27-2004 09:06 AM |
| Typical cutting force | Evilness | DIY-CNC Router Table Machines | 10 | 01-23-2004 03:01 PM |
