Old 05-05-2009, 02:15 PM
gepperta is on a distinguished road
Insert Milling Cutter Repair?
I need to know if it is possible to build up and repair a 3 flute roughing Valenite cutter we just broke. If so, I need a supplier name. Thing costs $400 to replace. I run a Community College Machining program and I'm not allowed to spend anything this summer.
It was the bottom insert that broke and the wiped out the holder edge.
Problem- T SLOT MILLING CUTTER PACKAGE 5 (ON WALTER CNC CUTTER GRINDER) dharschman Toolgrinding & Toolgrinding Machines 3 09-13-2010 12:25 PM
Milling cutter comp j44snk Okuma 6 01-14-2009 03:56 PM
Need Help!- 1-1/2 ball end insert cutter katsbobo Metal Working Tooling 3 12-29-2008 08:23 PM
Need Help!- Milling insert ID desperately needed! LakesideMachine General Metalwork Discussion 14 02-21-2008 08:06 PM
Insert Milling Tools? Joseph Souza General Metalwork Discussion 11 10-18-2006 08:26 PM
