I use 3" x 3" x 0.25" mild steel square tubing to build my CNC machine. I need to make sure I protect it from rust. I will be using a 4.5" wire grinder attachment to remove the rust already on the metal. What is the best way to stop future rust? I know I can buy the Rust-Oleum clean metal primer. Is there a better method and how many coats should I apply? I plan to spray some color over the primer. Any suggestions on what color I should use? Should I use dark colors (black, dark grey) or lighter colors (yellow, white, blue). Thanks, |
| coolman, Why not protect all the precision areas and then sand blast it , which removes rust not grinds over it, then a good coat of primer and some epoxy paint to finish it off, any color but battleship gray ![]() Blue would be cool. |
| HOw about this stuff? http://www.earlstation.com/earl_says..._mufflers.html
| Rust on tooling & toolholders | gbowne1 | General Metalwork Discussion | 20 | 01-23-2006 11:05 PM |
| Rust on Cast Iron | ChrisJ | General Metalwork Discussion | 10 | 05-18-2005 01:06 AM |
| Flood cooling rocks!!!! | JFettig | Benchtop Machines | 16 | 09-17-2004 05:01 PM |
