Old 05-01-2009, 04:33 PM
fireguy976 is on a distinguished road
VFD Enclosure help please
Hi all,
just purchased a Hitachi VFD in order to run my mill. The documentation recommends an enclosure to protect it.
Because of the size the Depot and other home centres do not carry anything near the size needed.
I checked out a local electrical supply and they want $85.00 for something near the right size.
What have the rest of you VFD users done?
Anyone made and enclosure? Would rather put 85 bucks into toling than some plastic box, thats for dam sure!!!!
Thanks,
Ken J
Old 05-01-2009, 06:29 PM
mactec54 is on a distinguished road
Hi fireguy976
You don't need an enclosure just mount it well & use shielded cable for the hook up & you will be up & running a photo just to give you an idea
Mactec54
Old 05-02-2009, 12:13 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Ken, it depends what you want to accomplish.
If you're going to run flood coolant, you probably do want an enclosure if the VFD is anywhere close to the mill (which it should be). Even without flood, chips go everywhere with my CNC, so I wanted an enclosure for my VFD lest one drop into one of the VFD's vent holes and really cause a problem.
One of the issues to look out for is proper ventilation of the enclosure without letting coolant and chips in. The VFD will throw off some heat, so make sure it can get enough cooling air. In addition to ventilation, the docs on your VFD will tell you how much air space needs to be on each side of the VFD--don't buy one too small!
I got a metal NEMA enclosure off eBay for mine. I think I paid $49 for it. There are probably cheaper enclosures to be had.
There is a little more detail on my web page here:
http://www.cnccookbook.com/CCMillCNCVFD.htm
Cheers,
BW
GT-20 or TL-2 with an enclosure? Donkey Hotey Haas Lathes 8 11-01-2008 10:44 PM
Another Enclosure : ) Rich05 Industrial Hobbies (Support forum) 12 06-12-2008 07:45 PM
tl 1 enclosure fourperf Haas Lathes 3 02-25-2008 04:56 AM
New All In One Enclosure mlaws1172 General Electronics Discussion 5 10-20-2006 07:26 PM
My Enclosure please take a look. Oldmanandhistoy General Electronics Discussion 36 03-03-2006 07:48 AM
