Old 05-01-2009, 11:59 AM
bigalexe is on a distinguished road
keep a 13" x 13" x 3/16" plate flat?
I have a set of 13"x13"x3/16" Aluminum 6061-T6 plate i am making into chessboards. My question is how to get the board reliably flat on the mill table preferably using only strap clamps. The table is about 10" in the Y so i can only clamp on 2 sides reliably.
The machining i am doing is a series of pockets that is every other square (im assuming you guys know what a chess / checkers board looks like) that is 0.010" deep on a grid 12"x12". Then i am doing some engraving on the sides of the board. So the finished product has a series of 1.5x1.5 pocketed squares and then some engraving on the sides.
The pattern on the boards has a 0.5" border i can clamp onto or i could clamp inside one of the squares not getting milled although ill have to check the collet clearances. I would like to do as much machining as possible on a single clamping.
How or better yet WHERE would you put clamps to hold this plate as flat as possible and also minimize the number of times the clamps need to be removed and repositioned.
Stuff i can use: AutoCAD 2010, AutoCAD Inventor 2010, Solidworks 2009, MasterCAM X2/X4, CNC's FADAL, and Hurco 3-axis CNC Mill
Old 05-01-2009, 12:58 PM
Matt@RFR is on a distinguished road
I don't know if you have the equipment in place allready, but this is the perfect part for a vacuum plate.
Need A Quote- .125" AL plate, cut (mill or laser), bent .125" ID bends Sporqster Employment Opportunity 0 09-23-2008 03:41 PM
Making brackets; bending 1/4" x 3" aluminum flat stock guru_florida Bending, Forging,Extrusion... 1 06-08-2008 05:48 PM
G320 "common" or "+5vdc" why do they vary? beezerlm Gecko Drives 3 01-12-2008 04:00 PM
Has anyone looked at the "JET" or "Shop Fox" manual machines? boosted General Metal Working Machines 12 03-04-2007 09:33 PM
How do I fix 4"x1/4" flat to 3"x3"x1/8 box without welding? Apples Mechanical Calculations/Engineering Design 7 10-18-2005 08:18 AM
