| Well you need a shaft to spin the tire and a head mounted on maybe to 1" dia rods, that will allow the head to move left to right. Than another pair of rods to allow the cutting bit to move in and out of the work. It's really not a complicated machine. I would first start with the mounting shaft for the tire, and draw a frame to support that. If you can give some specific info in size and tire and what type of motor you want to use to spin it this will help get this started. I did this in less than a min, but it gives you a idea-
__________________ Thank You, Paul G Site Owner-Webmaster- Administrator www.rfqwork.com www.cnczone.com www.welderzone.com |
| I see what you mean. When I get a change I will take measurements. Should I use the same motor as he uses on his? Also. How could I include a micrometer on the feed on this machine kind of like a lathe would have on the cross feed |
| You can make this thing CNC driven and control it via software.
really wow that would be awesome. I would like to keep the cost of the total machine below 2500-3000 though. maybe a little more if it is cnc. but the way the machine works is it has templates that create the same cut every time. You change the templates when you have a different size tire in the machine. I could easily machine the bolt pattern that goes onto the rim and I was thinking of having threads on the I.D.. and just having a fixture that screws in the I.D. threads inside of putting on the lug nuts. |
no way seriously? cause the guy I know sells this machine for 4700 5200 with some options he has. So you think he is profitting at least 4200 a machine WOW what a rip off |
| Well not really when you consider the cost of machining, for the do it yourself is almost always 1/3 the price.
#10
| Second machine design process | yukonho | CNC Wood Router Project Log | 134 | 03-28-2007 10:07 AM |
| My First CNC Machine, Mr. Chips | Mr.Chips | DIY-CNC Router Table Machines | 81 | 02-10-2007 09:04 AM |
| Confused about CNC software | samualt | General CAM Discussion | 22 | 06-30-2005 08:18 PM |
| Heads Up - Article about building CNC Milling Machine | samualt | CNCzone Club House | 3 | 06-13-2005 02:43 PM |
| FeatureCAM Expands Product Offering with Machine Simulation | CNCadmin | Product Announcements & Manufacturer News | 0 | 01-21-2005 06:58 PM |
