Old 01-19-2005, 05:29 PM
kellogs72 is on a distinguished road
Possible OT: Fab Aluminum washer
For a project I am working on I require some steel or aluminum washers. I have contacted several companies that can produce washers to specification but that ends up costing me close to $4.00 per piece. Cannot afford such an expense.
The size I am looking for would a inside diameter of .875", outside diameter of 1.8" and about .095" thick. I already have in my hands some square aluminum pieces that have the desired inside diameter and thickness but they are 2" X 2" square. Trying to figure out how to remove the corners and get it round. The blue line in the pic represents what I want to be left with after removing everthing outside the line. Can this easily be done?
Old 01-20-2005, 07:33 AM
kong is on a distinguished road
I don't know a great about it, but what about using a hydraulic punch? I take it you can buy or make a die easy enough?
Old 01-20-2005, 07:52 AM
coherent is on a distinguished road
If you can find some fender washers with the outside diameter you need, just drill your 5/8's ID on the drill press... it just depends on how critical your thickness requirement is. Check the mini lathe section. I have a lathe and it would be a fairly simple operations to machine some fender washers on the lathe to meet your specifications. It would be a bit time consuming depending on how many you need and how critial your tolerances are... but someone with a little time should be able to beat the cost you were quoted. Good luck
-marc
Old 01-20-2005, 08:10 AM
Gold Member
JFettig is on a distinguished road
how many are you looking for? you could get a chunk of aluminum, turn it down, drill the hole and part it off a bunch of times...
Jon
Old 01-20-2005, 09:49 AM
Gold Member
Ken_Shea is on a distinguished road
If you have a lathe it will be fairly simple.
Do you ?
Old 01-21-2005, 01:52 PM
pyroracing85 is on a distinguished road
i'll do it for you cheaper than 4 dollars for 1
Old 01-25-2005, 08:09 PM
i pmed you back. I'll do it half price than what they were asking. We'll make a deal out
-garrett
How strong? (Linear rails, aluminum structure) WoodSnarfer Mechanical Calculations/Engineering Design 13 07-15-2005 11:29 AM
CNC Aluminum studysession General Metal Working Machines 6 02-12-2005 09:39 AM
aluminum extrusion georgebarr DIY-CNC Router Table Machines 19 11-04-2004 09:43 AM
Can I use Forstner bits on aluminum? samualt DIY-CNC Router Table Machines 14 10-24-2004 12:35 PM
"shaping" aluminum? smythe General Metalwork Discussion 20 08-06-2004 11:35 AM
