Old 04-23-2009, 08:45 AM
markg71 is on a distinguished road
Complete Noobie Noob Question
Hi All
I would like to cut some slots into a metal pipe - probably either Aluminium, Brass or Stainless Steel. The pipe is only 5/16 and 6 slots need to be placed around its diameter in a staggered pattern and down its length..(this is for a 1/5 scale browning machine gun .303 cooling sleeve )
I didnt fancy using a dremel to do this, so am tempted to buy a small X0 mill for this and some other parts I may need to do.
All very light work, but, I am a little confused about the milling pieces I should use..I have heard a side cutter should do well, but the slots would probably be thicker than the cutters width, a ball nose should also do after the piece is drilled once to start it off but they dont like narrow cuts to work along or so I have also heard ?
So, thats my intended purpose, is the X0 machine a good choice for light, light work as I intend, and what milling pieces should I be using to achieve it, Finally, what is also the best way to clamp the pipe down as I probably will want it to slide along an axis so I can lift and mill a series of slots at once ?
Sorry if this is a dumb question, I have searched the net and maybe I am looking in the wrong spot, but I can't seem to find my questions answered anywhere
Kind Regards
Mark
Old 04-23-2009, 11:05 AM
djr76's Avatar
djr76 is on a distinguished road
Small 2 flute endmills will work. I would clamp it in a small 5c collet indexer with the proper sized collet, that way you can mill slots anywhere around the cylinder accurately.
Old 04-23-2009, 11:31 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Hi Mark. Welcome to the Zone!
An X0 is more of a small drill press than a mill. A drill cannot take the side force of an end mill. The X1 micro mill might do the job for you though--If the Z height will allow the length of the pipe. I would use a slitting saw or cutting disk to make those slots.
http://www.harborfreight.com/cpi/cta...emnumber=47158
OR, you could use a mini lathe with slitting saw or cutting disk in chuck, and a milling attachment to hold the pipe.
http://www.harborfreight.com/cpi/cta...emnumber=93212
http://littlemachineshop.com/product...1681&category=
http://littlemachineshop.com/product...1956&category=
CR.
Old 04-24-2009, 05:33 AM
Evening
Thanks for your replies...Ultimately, which do you think I would get more use out of considering the type of work I intend to do...
A Mini-lathe ?
or
a Mini Mill ?
I would love to get both, but the financial controller is in need of some persuasion for that argument..
Is the X1 a good mill to get, are you able to give me any ideas for contenders in the beginners market for both mills and lathes ?
I have seen Sherline and Proxxon models but fairly little else in that price bracket
Sorry for the barrage of questions, I am searching the net, but I am a little restricted being in Australia as to my manufacturers and options I can choose from
Kind Regards
Old 04-24-2009, 11:00 AM
Originally Posted by markg71 View Post
Evening
A Mini-lathe ?
or
a Mini Mill ?
I can't answer that for you. Maybe if you watch these machining videos, you can decide that for yourself:
http://techtv.mit.edu/videos/142-machine-shop-1
Proxxon is extremely tiny. Sherline is both tiny AND very expensive. The X1 Micro Mill is small, but actually can do a lot considering what they cost. An X2 Mini Mill is a reasonably capable beginner mill.
http://www.harborfreight.com/cpi/cta...emnumber=44991
Most bang for buck in a larger, MORE capable mill is the Sieg X3:
http://grizzly.com/products/Mill-Drill/G0463
The 7 x 10 mini lathe is actually only 7 x 8. That doesn't leave much room for stock AND a drill bit. 7 x 14 is much more usable. But light weight lathes are not as rigid as heavier lathes.
Most bang for buck in mini lathe is much heavier Harbor Freight 8 x 12. (Which is ACTUALLY 8 x 14)
http://www.harborfreight.com/cpi/cta...emnumber=44859
Most bang for buck in a larger lathe is Grizzly 10 x 22:
http://grizzly.com/products/10-x-22-...al-Lathe/G0602
CR.
noob question manufan Post Processors for MC 4 06-04-2008 11:34 AM
OK- Complete Noob; I need a mould made chakup Moldmaking 6 05-12-2008 05:59 PM
a noobie question justCNCit General Electronics Discussion 7 08-18-2007 09:35 AM
linear bearings noobie question s_a_black Open Source CNC Machine Designs 1 04-25-2007 08:24 PM
Noob question PBfan General CAM Discussion 12 07-05-2006 11:19 PM
