hi all first post on here. im machining small parts 5 off on a long block of ally all the same. im using 2 labels for different profiles on the part and repeats to get to my depth. as im doing 5 off the same on the one bar so easy to use datum shift,i call datum shift x+29mm(increment)label call 1, rep 3times,label call 2 ,rep 1 time etc,trouble is it keeps repeating the label in a circle and when it should be finished and go to z+150 it goes to do another part in fresh air. any ideas?? thanks |
If you could put the program on here it would help a lot . |
| HELP!! Heidenhain PC interface Problems | servocontroller | Bridgeport and Hardinge Mills | 4 | 06-11-2009 06:05 AM |
| Problems starting up Heidenhain Tnc155 | Oviksnc | General Electronics Discussion | 15 | 12-18-2008 03:54 PM |
| Heidenhain programing help | lazerracing | Bridgeport and Hardinge Mills | 4 | 12-04-2007 06:05 PM |
| Contouring problems Heidenhain 155 | praest | General CNC (Mill and Lathe) Control Software (NC) | 12 | 09-14-2007 05:53 AM |
| Heidenhain programming problems | lt1pat | General CNC (Mill and Lathe) Control Software (NC) | 1 | 03-12-2006 10:28 AM |
