Old 04-20-2009, 10:47 AM
GOZUKI is on a distinguished road
2" NPT turning
Hi all, I am having difficulty coding a 2"-11 1/2 NPT OD thread on a Mori Seiki NL2500. Can anyone give a little help on my G76 values? Thank you all!
Old 04-20-2009, 11:22 AM
g-codeguy is on a distinguished road
X2.42Z.5
G76P000129Q30R.002
G76X2.2735Z-1.25R-.0545P696Q150F.087
You didn't indicate the length. Guess you can figure it out from here. Haven't run a 2" O.D. before, but this should do the trick. Layed it out per the Machinery's Handbook.
Old 04-20-2009, 11:49 AM
Curious why you omitted the A value?
Old 04-20-2009, 02:26 PM
There is no A value in the 2-block call. Figured you had a newer machine. The single block call would be
G76X2.2735Z-1.25I-.0545K.0696D150F.087A50.
You also have a choice of P1 through P4 for a single block call which determines the manner in which the thread is cut.
For the 2-block call A-value is the last pair of numbers in the first block P callout. There are only 6 choices. I used 29 degrees in my example.
EDIT: Single block A-value can be any whole number far as I know.
Old 04-20-2009, 03:05 PM
mrainey is on a distinguished road
The R value is negative for an OD thread?
Software For Metalworking
http://closetolerancesoftware.com
Old 04-20-2009, 05:03 PM
It is on our OT, 18T and 21i-T controlled Hardinges, Daewoos, Nakamura Tome, Takisawa, and Mori Seikis. Also on the Yang with a Mitsubishi control. The X in the G76 block is the end position. It is at the front position on our Okuma, but the Okuma does not have a Fanuc control or use a G76 for threading.
Old 04-21-2009, 07:16 AM
Thanks for the info.
Need A Quote- 304SS Tube 3" (1/16 wall) x 19.5" Cut-Off, Turning, Drill or Punch onecoolone Employment Opportunity 1 11-19-2008 08:17 AM
BattleAxe "aka" Ball and Chain "aka" the wife. ZipSnipe CNCzone Club House 48 05-18-2008 09:53 AM
"Turning on" rigid tapping? PoiToi CNC Swiss Screw Machines 13 04-15-2008 03:30 PM
Turning 2" OD Delrin on an X3- power issues? iamscottym Benchtop Machines 5 08-24-2007 07:43 PM
2" aluminum cnc turning RFQ fastolds Employment Opportunity 7 09-20-2006 02:49 PM
