Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: What junk have you gotten stock from?
    Mar 2009
    Would love to know where other people have gotten any type of stock from. A little while back I got a 1/2" thick board of plastic which was originally the counter you buy your food over at McDonalds. I don't know what I'm going to do with it yet. It's more brittle than I thought, it tipped over and cracked in half when I got it home so it's harder and more brittle than ordinary plastic.
    Dec 2008
    Bad Plastic
    Quote Originally Posted by slashmaster View Post
    Good Morning, Slash.
    I read your message and Know exactly what you are talking about. I work at mid-America Plastics and we sell plastic Sheets . We have Polypro to Halar Plastic. If Interested in buying good product Please call. Attn Blake #1-800-468-1501
    Mar 2009
    Quote Originally Posted by Bob Bokusky View Post
    Thanks bob,
    Would you happen to know if what I got sags when it bakes in the sun? I wanted to make it into a rear decklid for a car but now that I cracked it in half I guess I'm going to have to think of something else to use it for.
    Dec 2008
    Thanks bob,
    The Material you have is just a Guess? I think it is probably PVC which is very Brittle. I would recommend Polypro Plastic. In real Hot climates even Poly Will warp a little but not Crack. UHMW Plastic would be expensive but hold up the Best in all situations.
    Mar 2003
    Shelby Twp, MI....USA
    I think it's Corian. We did some work at a few McDonalds a few years ago, and that's what the counters were. And it comes in 1/2" thickness.
    Registered mc-motorsports's Avatar
    Feb 2007
    corian is brittle, but absolutly free machining, as fast as you can go, no worry about chips loading up or welding, they turn to dust. Your only limit is spindle speed and it polishes up real nice.
    BTW, Corian is only 35% plastic? The rest is minerals? Something like that.
    Mar 2009
    Quote Originally Posted by mc-motorsports View Post
    Great! Thanks for letting me know! Has anyone here used an aluminum car bumper to make something out of?
    Mar 2003
    No, Corian is all plastic.
    Registered Shotout's Avatar
    Jun 2006
    Quote Originally Posted by ger21 View Post
    How dimensionally true is the flatness of Corian? A friend suggested it as a top for my roll around. I want to use it as a surface plate for setups prior to sending a part to QC for CMM checks.
    Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself.
    Mark Twain
    Mar 2008
    Corian is a mineral / binder mix. It is not all plastic.
    Corian is fairly flat but a poor substitute for a proper granite roll-around. If it's for the top of a toolbox it might work pretty well. It's fairly impact resistant and the good thing about it is you can resand and repolish many times and even cracks can be repaired and resanded. It's practically inert to common shop chemicals. It's not good enough for an inspection plate or CMM base. It's only 1/2 thick.
    As for the question at hand about stock from junk I only do that with wood for my burl projects. I just don't find it worth the time and effort to machine a smaller spoon from a bigger spoon.
    Registered extanker59's Avatar
    Mar 2008
    "Corian
    From Wikipedia, the free encyclopedia
    Corian® is the brand name for a solid surfacing material created by DuPont which is composed of acrylic polymer and alumina trihydrate. It is said to be a thermosetting plastic, but can be thermoformed by heating it to 300°F (149°C), allowing unique shapes to be created."
    There's more.
    No input on the actual subject but I just wanted to help clear this up.
    I wonder what alumina trihydrate is?
    Jan 2008
    England
    Quote Originally Posted by extanker59 View Post
    "Corian
    Its aluminum Hydroxide Al(OH)3 Its an aluminum compound that is an intermediate in extracting aluminum from bauxite, a really fine white powder.
    I work with Corian and its a brilliant material, heat a strip in an oven about 180C and you can literally tie a knot in it before it hardens and feels almost stone like.
  • Page 1 of 2 12 LastLast
    1. Old junk Makino Wire Cut
      By Ch_Irawan in forum General Waterjet
      Last Post: 08-10-2008, 08:11 AM
    2. New Machine Build- junk box precision mill
      By KTP in forum Benchtop Machines
      Last Post: 04-28-2008, 09:25 PM
    3. Junk foam CNC?
      By ls7corvete in forum DIY CNC Router Table Machines
      Last Post: 03-15-2007, 11:29 AM
    4. Junk Physics
      By flakker in forum Benchtop Machines
      Last Post: 10-21-2006, 07:43 AM
    5. head stock and tail stock chucks
      By mocnc in forum DIY CNC Router Table Machines
      Last Post: 10-19-2004, 10:16 PM
