im having a hard time with the geometry of designing a sprocket, does anyone know of a sprocket calculator? i am using a somewhat older version of featurecam, which has a gear wizard, but i still cant get it to work. i found on called 'the sprocketeer' online but it didnt work. i am trying to make a sprocket for a bicycle chain which is considered one of the standard sized roller chains, any help would be great. |
| What exactly is the problem you're having with the geometry? How Large of a Diameter are you going for here? If you can measure the circumfrential length between the center of two teeth on an existing sprocket for a bicycle chain.
__________________ -JWB --We Ain't Building Pianos (TCNJ Baja 2008) |
| Go to Boston Gear - sprockets:http://www.bostongear.com/pdf/upload...%20175_196.pdf |
http://www.wadeproco.com/ Cheers, Les H. |
| Sprocket Profile Generation | big_mak | Mechanical Calculations/Engineering Design | 9 | 08-16-2010 08:25 PM |
| Sprocket milling macro ??? | theemudracer | G-Code Programing | 20 | 11-08-2007 07:17 PM |
| RFQ: Sprocket (closed) | mcraig79 | Employment Opportunity | 7 | 07-03-2007 07:30 AM |
| Gear sprocket software | PlasmaGuy | Mechanical Calculations/Engineering Design | 4 | 05-15-2007 06:27 PM |
| Sprocket teeth | MattMachinist | General Metalwork Discussion | 0 | 04-17-2006 10:06 PM |
