I have a very nice, water cooled spindle that runs beautifully. The water is pumped using a small, water feature pump and is more than adequate for the job. However, after a few days, the water in the supply tank takes on a life of its own, growing weird and wonderful cultures. I have tried using a weak bleach solution and it helps but just delays the inevitable growth. Can anyone suggest an additive or solution to my problem? Many thanks, Mike |
| Mike, You might want to try Dowtherm SR1. Used in Precise High Speed Spindles to keep this German brand of spindles running cool. Mixed with 2 parts water to 1 part Dowtherm SR1. Dowtherm SR-1 is a special pink colored mix of ethylene glycol(anti-freeze). Also, google "Precise Spindles" for more info. Hope this helps. Link: http://www.dow.com/heattrans/prod/glycol/dowtherm.htm Jack |
| Hi Jack, Thanks for the reply but it seems that Dowtherm SR-1 is not available in Europe. Maybe it has another trade name over here. I used the product locator on the Dow website but no results for Europe!! I will look for other glycol based systems over here. thanks, Mike |
| Just a thought, a little copper sulfate will kill this stuff off for sure. I've used it in my water bed for thirty years now. i don't know, but can't see where this would cause trouble with your spindle coolant. karl |
| Perhaps you dont like it but why separate watere cooling at all - my coolant flows through spindle - kill two birds with one stone - one pump, the same fluid. ->Tank -> filter -> Pump -> Spindle -> Coolant nozzle -> ..... Selfmade brushless direct drive spindle, 1kW, 45.000 RPM Cheers, Herbert |
| Hi Herbertkabi, I don't understand what you are saying My system is a closed loop of tank, pump and spindle. The water re-circulates constantly but after a time it becomes cloudy and organisms start growing.Mike |
| You could do a search for coolant additives for water-cooled PCs; they're meant for keeping fluid systems like that clean and germ-free. I ran my computer without it for a while and it did the exact same thing. With the additive I used, it stays clean, and lasts until it goes a little brown from air exposure. Cheap, too. Jim
__________________ No time to do it right, plenty of time to do it twice. |
#11
| this is my older machine coolant and spindle cooling I made few years ago, you can see how hoses ... this spindle is not so "nise looking" but it is good (45k rpm) pump is also tiny - exact like yours ("The water is pumped using a small, water feature pump and is more than adequate for the job.") - yes, some of these tiny 12v pumps are very good! Pump is electronically controlled ... You can use how many closed loop water-systems you like - I prefer just all in one ![]() cheers, herbert Last edited by Herbertkabi; 04-13-2009 at 05:24 AM. |
#12
| Hi Herbertkabi, Nice looking spindle - do you have drawings and/or instructions on how you built your spindles? Is there a thread on the 'Zone'? I am very interested. The controller, strapped to the side looks very much like a model speed controller for brushless motors. Also, what is the device on the table in the bottom right of the picture? Thanks, Mike |
| Another effort, 2 cylinder inline water cooled | balsaman | I.C. Engines | 205 | 03-01-2011 03:53 AM |
| cnclinx water cooled spindle | endgrainguy | DIY-CNC Router Table Machines | 3 | 09-25-2008 02:58 PM |
| Water Cooled Condenser | Smackre | Hobby Discussion | 13 | 05-07-2008 11:49 AM |
| Water cooled spindle need ??? | BFcarbon | Commercial CNC Wood Routers | 6 | 03-04-2006 04:05 PM |
| Is this spindle meant to be cooled with air or water? | Darc | DIY-CNC Router Table Machines | 2 | 10-22-2005 10:22 PM |
