Old 04-09-2009, 04:18 PM
Gmaan is on a distinguished road
Nakamura CNC Lathe/Fanus 10t Question
I am starting to work on a Nakamura Lathe with a Fanuc 10t control. The X axis is reversed?
X0 = Part C/L
X-1.0 will produce a part that is 2.0 inches in diameter.
X-2. = 4" Diameter.
This seems backwards? What parameter can I check to verify or switch the direction.
Old 04-10-2009, 07:45 AM
Kool Parts's Avatar
Kool Parts is on a distinguished road
If no one here chimes in then give your Methods office a call. They can get you up and going.
Gary
Old 04-10-2009, 08:22 AM
extanker59's Avatar
extanker59 is on a distinguished road
I just glanced at my proven sample program for a Nakamura TW10 lathe.
The X is not reversed. X2. results in a part 2" in diameter. I can't think of a setting or parameter that would do that. I'm stumped.
Old 04-10-2009, 09:56 PM
gthal is on a distinguished road
Question
Look in the geometry offset page for that tool ,it seems you have +1.0 to the c/L and a -1.0 = 2.0 that makes me think its an offset .
Old 06-15-2009, 09:04 PM
MMTZ is on a distinguished road
From my experience, some people will set X=0 to the center of the spindle so they can leave any drill or center cutting tool offset to "0" on the X axis geometry. This is so that they don't have to center every tool on each setup. It works when you are not making any small holes or tight toelrance holes. It also helps when you have boring bars, what you would do is to make the boring bars X geometry offset equal to the negative value of the bars minimum bore size.
Try making an ID tool offset zero and run
T####
X=0
on the MDI mode, if it aligns tho holder to the spindle center then that's what the previous owner used to work on that machine.
I hope this helps
Need Help!- Nakamura SC-300 sub milling Lind-Rite G-Code Programing 0 07-11-2008 03:56 PM
Nakamura Tome Question craven12 General Metal Working Machines 4 04-22-2008 03:05 PM
Nakamura help? LocTite98 General Metal Working Machines 0 01-22-2008 03:34 PM
M91 in nakamura tw-10 maximusek G-Code Programing 25 01-15-2008 06:47 PM
Mori Mill and Nakamura Tome Lathe leggetmachine General Metal Working Machines 2 08-29-2006 12:54 PM
