Old 04-07-2009, 07:04 PM
cncwhiz is on a distinguished road
Specs for a 4 3/8-8 thread
We have a part that we need to make a 4 3/8" male and female thread. The handbook does not go that big?
Old 04-07-2009, 07:47 PM
flick is on a distinguished road
It has specs for a 1 3/8-8 thread right? Just add 3 to everything.
Old 04-07-2009, 07:51 PM
asuratman is on a distinguished road
Let me know what handbook you are using for that thread. I need also to cut some thread like nu10rd, eue8rd, buttress, VAM, etc. Thanks.
Old 04-07-2009, 10:31 PM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
subtract the pitch to get the minor diameter. 1 divided by 8 = .125" 4.375" - .125" = 4.250" minor diameter.
I'm not 100% sure that that works for threads that large. But it works for up to 1"... 3/8"-16 for example. 1/16=.0625. .375"-.0625"=.3125" minor diameter. For metric, just subract the pitch. M8 X 1.25 = 8-1.25=6.75mm
MC
Old 04-08-2009, 08:52 AM
beege's Avatar
beege is on a distinguished road
Michael Rainey has a program called "Threadpal". I recommend it, especially for all odd-sized threads you may encounter. I get a pitch diameter of 4.2817 to 4.2910 when I input your givens into Threadpal.
http://closetolerancesoftware.com/index.html
Old 04-08-2009, 09:56 AM
MC
That is not exactly correct is it?
For instance your example using 3/8-16 gives 0.3125" which is the drill size to use for 75% full form thread so it is actually large than the minor diameter.
It is a good approximation for tapping but for cutting a thread I think it will leave a wide flat crest.
Old 04-08-2009, 10:56 AM
g-codeguy is on a distinguished road
As already stated, find a thread size with the correct pitch you need. Add/subtract the difference. Size of thread doesn't matter. Thread height will always be the same for a given pitch/lead regardless of the size. A 1/4-20, 1/2-20, 1-20, 4-3/8-20, etc. all have the same thread height. This works for major/minor/pitch diameters.
Old 04-08-2009, 11:37 AM
Beege,
That program is great. My boss is thinking about buying it. Anybody have any more sites like that? Good info.
Old 04-08-2009, 03:42 PM
I'm going on memory here, so correct me if I'm wrong: the basic UN spec calls for a 1/6 flat at the crest and 1/24 flat at the root of a female thread. 1-(1/6)-(1/24) = 0.791 = around 79%. TDS is not 75% of a full-form, or normal thread, it's 75% (actually 73.08%) of a full, sharp V, which is really a negligible difference for most practical purposes. 75% is used in tapping rather than 79% (or 73.08%) because:
A) It's easy for sleepy machinists to remember.
B) The thinnest part of the thread contributes the least to it's strength.
C) The thinnest part of the thread contributes the most to cutting forces.
D) It's easy for sleepy machinists to remember.
Usually when I single-point a UN thread I just bore to tap drill size, for all of the reasons stated above.
I would not do this if a drawing specified a 1B thread, rather than the usual 2B, or if I was making a gage.
Old 04-08-2009, 04:42 PM
Originally Posted by flick View Post
I'm going on memory here, so correct me if I'm wrong:....
I think you are correct. It is just if you are making a large coarse thread the flat will look quite wide at 75%. I would do this for an in-house job but for a customer I would be more cautious; if the customer questions it you do not in fact have it exactly to spec.
Another reason for using 75% is because practically all the tap drill charts use this; no memory needed.
  #11   Ban this user!
Old 04-08-2009, 04:48 PM
Too true. I have not been caught on this, but YMMV.
  #12   Ban this user!
Old 04-08-2009, 08:12 PM
My drill chart shows a 1-1/2"-6 thead having a 1-11/32" tap drill ending up with 72% thread.
A 75% thread requires 20% less power to cut, and is only 5% weaker than a full thread.
That's only for "open tolerance threads". If you have a tolerance specified, better look it up and gauge it.
Need Help!- Thread spec for camera lens filter thread cmays General Metalwork Discussion 3 08-22-2010 02:14 PM
acme thread combos and thread mixing calaber40 Linear and Rotary Motion 5 05-15-2009 09:04 PM
Thread mill external NPT thread cutting edge General Metalwork Discussion 11 09-15-2008 09:33 AM
Need Help!- M42 x 2 thread, first thread is sharp! Driftwood General Metal Working Machines 5 07-19-2008 12:09 AM
Stepper Specs (Was Servo Specs) plexer Stepper Motors and Drives 1 09-29-2005 10:28 AM
