My gantry router is working great except one problem. When I route a square, the corners are not square. The straight sections are good but when I approach the corner there is a bump out. I'm not sure if it is a backlash problem or flexing in the router bit. I don't think it is a backlash problem because when I mill a circle it is perfect. I'm using a Bosch Colt router with a 1/4" spiral bit. I've tried slowing down my feed rate to 20ipm and depth of cut of 0.1". The problem still show up. Here is a drawing what the corners look like. You do you guys think? |
| Can you try the same program with a larger dia bit, or possibly a bit with more flutes? I doubt it, but you may have a problem with the bit flexing. How heavy of a chip are you taking? For my 3 Onsrud routers I refuse to run a 2 flute 1/4" bit at anything faster than 18,000 rpm and 350ipm. I tend to want to see your code to see if your post may be kicking out something weird, your cut is not deep enought to really cause you a problem like this unless your spindle speed is way too low. |
| here is my code. N10 G00 Z 0.10000 N20 G00 X 0.00000 Y 0.00000 N30 G01 Z-0.10000 F20.00 N40 G01 X 1.00000 Y 0.00000 F50.00 N50 G01 X 1.00000 Y 1.00000 N60 G01 X 0.00000 Y 1.00000 N70 G01 X 0.00000 Y 0.00000 N80 G01 Z-0.20000 F20.00 N90 G01 X 1.00000 Y 0.00000 F50.00 N100 G01 X 1.00000 Y 1.00000 N110 G01 X 0.00000 Y 1.00000 N120 G01 X 0.00000 Y 0.00000 N130 G01 Z-0.30000 F20.00 N140 G01 X 1.00000 Y 0.00000 F50.00 N150 G01 X 1.00000 Y 1.00000 N160 G01 X 0.00000 Y 1.00000 N170 G01 X 0.00000 Y 0.00000 N180 G01 Z-0.40000 F20.00 N190 G01 X 1.00000 Y 0.00000 F50.00 N200 G01 X 1.00000 Y 1.00000 N210 G01 X 0.00000 Y 1.00000 N220 G01 X 0.00000 Y 0.00000 N230 G01 Z-0.50000 F20.00 N240 G01 X 1.00000 Y 0.00000 F50.00 N250 G01 X 1.00000 Y 1.00000 N260 G01 X 0.00000 Y 1.00000 N270 G01 X 0.00000 Y 0.00000 N280 G01 Z-0.60000 F20.00 N290 G01 X 1.00000 Y 0.00000 F50.00 N300 G01 X 1.00000 Y 1.00000 N310 G01 X 0.00000 Y 1.00000 N320 G01 X 0.00000 Y 0.00000 N330 G01 Z-0.70000 F20.00 N340 G01 X 1.00000 Y 0.00000 F50.00 N350 G01 X 1.00000 Y 1.00000 N360 G01 X 0.00000 Y 1.00000 N370 G01 X 0.00000 Y 0.00000 N380 G01 Z-0.73000 F20.00 N390 G01 X 1.00000 Y 0.00000 F50.00 N400 G01 X 1.00000 Y 1.00000 N410 G01 X 0.00000 Y 1.00000 N420 G01 X 0.00000 Y 0.00000 N430 G00 Z 0.10000 I'm using 1/4", 2 flute, at 18000 rpm in MDF. I'll try running at a higher RPM later. |
#10
| Are you using “constant velocity” or “exact stop” in Mach? Not sure if this could be the problem but if you have CV set try switching to ES. What are you using for anti backlash nuts, if there your own design do you have a picture? John |
#12
| Backlash or motor tuning problem? How do I test for backlash? | Brian Queen | Mach Mill | 8 | 03-10-2008 04:35 PM |
| Backlash problem | birchie | Okuma | 4 | 12-30-2007 05:33 PM |
| Question about problem / backlash | tikka308 | Benchtop Machines | 1 | 10-22-2007 07:49 PM |
| A axis backlash problem | Art Ransom | General Metal Working Machines | 0 | 09-11-2006 07:38 AM |
| Backlash problem | devincox | Benchtop Machines | 6 | 08-17-2005 02:10 PM |
