Old 04-03-2009, 12:33 PM
cnc steve is on a distinguished road
Tension & Compression tapping
I have been using some old Kennametal, straight shank tapping holders. The shank is 20mm in diameter and the overall length is around 185mm long.
I think the collets we use are the DA200 (J) type collets with the cut out in the bottom and square end. Can anyone confirm this collet as shown in the photo.
Also does anyone know of a similar or the same tension and compression tapping holder that I can still purchase in the uk and collets to suit. Most of the tapping is for M3, M4, M5 and M6 ISO.
I have sort of hit a brick wall with trying to locate information on these holders and collets and appreciate any help and info you can give me on them.
ID:	78986   Click image for larger version
Old 04-03-2009, 11:04 PM
Oldmanandhistoy is on a distinguished road
http://www.tapmatic.co.uk/ Any good?
John
Old 04-04-2009, 03:28 AM
I have tried them, I want something similar to what is in the photos or it means changing collet systems etc..
Old 04-04-2009, 06:10 AM
Superman's Avatar
Superman is on a distinguished road
We have used them, they are a Kennametal / Erickson holder with 3/4" or 1" shaft and a DA (J) collet system and are interchangable
checkout
http://www.tools-n-gizmos.com/specs/...al_Collet.html
http://www.sommatool.com/catalog/eri...ap.collets.asp
you have a "SOMMA" distributor in the UK -see....http://www.dpautomatics.com/
https://www.kennametal.com/e-catalog...y%3A4698&logo=
my google was- erickson tap collet
Nikken Tension Compression Tap Holder rbleth51 CNC Tooling 1 07-15-2008 09:49 AM
Tension Vs. Corriente brutto Spanish CNCzone 0 01-16-2008 03:52 PM
Hydraulic compression endmill holders Geof CNC Tooling 1 12-08-2007 09:09 PM
Thread Milling using a Compression Tool holder chase78 G-Code Programing 4 06-01-2007 02:23 PM
Tension/compression tap holders Caprirs General Metalwork Discussion 8 04-05-2007 08:59 AM
