Old 04-02-2009, 10:44 AM
coolantman's Avatar
coolantman is on a distinguished road
Extending the Life of Coolants
In order to extend the life of your coolants and metalworking fluids, it is very important that any tramp oil should be removed from the tank. Chemicals are available that can be added to the coolant to protect emulsions from reactive metal fines, reject the tramp oils to the top of the tank, and extend the life of the coolant. Oil skimmers are usually the easiest solution for removing rejected oils
The presence of swarf and tramp oil create an environment that helps the growth of bacteria. Aerobic and anaerobic bacteria and fungi eat the organic components of the coolant reducing the effectiveness of it. Therefore, bacteria and fungi should be removed from the coolant or prevented from growing in the coolant. MWF Biocides can be added to kill any that exist.
A great coolant management system can be put in place by your supplier to help control usage, life, and overall coolant cost.
-Coolantman
EnviroServe Chemicals, Inc.
(910) 892-1791
www.enviroservechemicals.com
Coolants coolantman Product Announcements & Manufacturer News 0 03-18-2009 12:26 AM
Need Help!- extending the table EStegall Want To Buy...Need help! 0 10-17-2008 01:44 PM
coolants jprobst Haas Mills 1 09-28-2007 07:35 PM
Extending text to a surface? lotsa luck BobCad-Cam 2 02-24-2005 08:21 AM
extending THK rails, rail alignment Cliff_J DIY-CNC Router Table Machines 1 05-28-2004 01:09 PM
