Does anyone know a place that sells endmills for cutting splines? Seems to me I've seen somewhere but I cant recal. The drawing calls for: 16/32DP 30 Deg PA 1.750 Major Dia 1.589 Minor Dia 27 Teeth Looks like an involute style. I need and endmill since I am making this part on a VMC, also it is very close to a shoulder. Thanks for any info Last edited by laka; 04-02-2009 at 04:35 PM. |
| Could you put a hob on arbor and run this? Not aware of a standard endmill to do this? Heck...... that's why I visit this site though, I always keep learning! I am sure you could find some kind of a hob with those demensions required and run it off an arbor in a e/m holder and side machine it. |
| Using an endmill and cutting right on your centerline, you won't get a radiused minor diameter. I suppose you could index the shaft so each spline flute is vertical, and side mill them, and at least get a faceted minor diameter. |
| Is this a production situation or a one off? I've never seen any commercial offering of endmills that will do this. I can well imagine the extreme delicacy of the tip of such an endmill, resulting in a short useful life for the tool. I would side mill it. For a single job, grind up a flycutter and make a little arbor to hold it in a regular endmill holder. However, grinding the tool requires a sample spline to test the tool shape. If you have a male spline sample, you can cast an inverse off of it with a bit of plaster of Paris, then you've got a gauge to grind and fit the tool to. For production, you could likely get a tool grinding shop to custom make the tool, using something like a woodruff cutter as a basis to begin from. A small woodruff cutter might get you within 3/8" of a shoulder. If you must get closer to the shoulder than that, you'd almost be looking at some sort of EDM procedure.
| You can cut on the side of the part with a form milling side mill or end mill. www.tmfmllc.com www.ashgear.com Ash might rent one if it's a short run or one-off. Dick Z
__________________ DZASTR |
| I ended up getting one custom ground for me. It is for a one-off job. I had to go with an endmill since the splines stop very close to a chamfer. Minor diameter is not a big deal, they just need it to fit nicely in the female socket. Thanks for he help |
| cutting splines?? | inthedark | General Metal Working Machines | 12 | 04-28-2009 11:07 PM |
| Cutting Internal Splines? | Krusty Karl | General Metalwork Discussion | 10 | 11-12-2008 12:32 PM |
| cutting splines with mill | astro | General Metal Working Machines | 1 | 08-18-2008 07:55 PM |
| Feed rate? Slot cutting with 0.031" endmills? | Donkey Hotey | Haas Mills | 5 | 03-27-2008 02:24 PM |
| Help with splines | CNCRob | Autodesk Software (Autocad, Inventor etc) | 2 | 09-03-2005 04:14 PM |
