| Hi (just so you know I’m 18 so I’m new to the whole CNC mecheine category) I’ve just started to “work” at a company and I have a sort of assignment to do but I could use some help since I don’t know so much about Milling. ![]() First of all what is Exotic Materials, because what I uderstand it is Nickel, Cobolt and Stainless steel Alloys, Mercury, Titanium and Tungsten. This I got from a recycle center so I don’t know… Second is there any special application and equipment you need to work with exotic materials? |
| There is also Waspoloy, Haynes #49, Inconel, and Monel to name a few more. What is it that they want you to do or make?? This is what we will need to know in order you help you.
| Well I’m in the development part of the company so we’re sort of going to investigating exotic materials to mill in and (if I understand right) depending on materials maybe to use for end mills. But first I need to find out the basics and get the right compitence and that is what I have a problem with. Last edited by heisawoman; 04-02-2009 at 10:08 AM. |
| Exotic material just means "unusual" material, like stuff you'd only machine once or twice a year. For example- lenses are usualy made of glass, exotic material for lenses would include Germanium, Zinc Selenide, Arsenic Trisulphide etc- just stuff that isn't the normal run of the mill stuff.
__________________ I love deadlines- I like the whooshing sound they make as they fly by. |
| First off when someone says exotic materials most guys cringe. Usually most of what Toby listed describes exotic. The machines and setup need to be solid and rigid. Your cutting speeds and feeds are very slow. Exotic materials eat tooling. In my business I like that! Most think of exotics when you know you are going to machine aerospace and some military parts. |
| Some stuff on Iconel: http://en.wikipedia.org/wiki/Inconel http://www.hightempmetals.com/techda...nel600data.php http://www.azom.com/Details.asp?ArticleID=4461 http://www.espimetals.com/tech/inconel718.pdf Waspaloy: http://en.wikipedia.org/wiki/Waspaloy Haynes alloys (but not #49 for some reason!) http://www.haynesintl.com/pdf/h3061.pdf Monel stuff: http://www.lenntech.com/Monel.htm All these were found (and many more) using google with "XXX material properties" where "xxx"= the material you listed
your making endmills ? what is your reason to need to develope a product or part with an exotic material , can you not find a standard material to use ? there would be a great economic benefit to it if you can exotics are generally much more expensive due to the fact the demand isn't high plus the cost of materials that are in it , not to meantion the wait that you may face in ordering material
__________________ A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org |
| The reason is that the custemers are asking for it (or to have an alternative), so we're considering, and we're doing reasearch on what materials exotic or not that could be used. Thanks for the links ImanCarrot. Last edited by heisawoman; 04-07-2009 at 03:26 AM. |
#10
| Though your information have helped I don't know if I'm more confused now or before I started. I have a new question Does any one know what the most common exotic alloys to mill are (what kind you use the most of the exotic materials)? Last edited by heisawoman; 04-09-2009 at 07:10 AM. |
#11
| Anything NASTY!! There is a company that works specifically with Exotic Materials in this area called Refracto Technologies. Ask for Kenneth. 631-563-8580 These guys work with all the nasty materials .
| Tags |
| exotic material, milling |
| Exotic Materials | stuby | General Metalwork Discussion | 2 | 01-28-2009 12:04 PM |
| Where to buy materials? | Chevy-SS | General Metal Working Machines | 13 | 01-26-2009 07:36 PM |
| Making exotic hardwood jewellery | Synaptic | CNC Machining Centers | 12 | 02-14-2007 05:30 AM |
| Hard and Exotic wood routing? | Crushmonkey | WoodWorking | 5 | 05-22-2005 02:41 AM |
