Hi All i need help cutting 2mm copper I am using Infotec CNC router with ELTE spindle 0.75 KW power and 15,000 RPM. I need to cut small parts i am using carbide 1mm, and 2mm diameter I need to know the best setting to do that because i already broke some bits please help to identift the right RPM, Feed speed and step down for my bits P.S. i am not using any coolant maybe any one suggest what to do??? Regards |
| Have not done copper for a while, it's a gummy material Carbides running too fast tend to push up major burrs and not slice it off. Use Steel speeds and feeds, with extra sharp cutters, (HSS or Carbides for aluminium) For coolant - some suggest kero, something to stop chips sticking, for example see http://www.iscar.com/Ecat/familyHDR....type/1/lang/EN |
| Don't know about laser, especially with copper. waterjet ?? plasma may melt the copper Depends on quantity, accuracy, etc. required, or the details that need machining ? Large quantity - could possibly be stamped and / or folded leaving hole/s to drill maybe ? Just throwing other options up in the air |
| Waterjet is known for being able to produce tight tolerances, we stay within a few thousandths of an inch. Machine prices are pretty steep but cut prices vary with runtime. 2mm copper wouldnt take very long to cut. |
#11
| I dont know about purchasing a waterjet with such a small table, I have heard of 4'x4' tables, but not much smaller than that. If you are just looking at having a few parts made, you can send me some drawings and see if that's something we could cut. |
| Cutting copper sheet? | bossfrog | CNC Plasma and Waterjet Machines | 3 | 09-03-2011 12:27 AM |
| Cutting rates for tellurium copper | Silentelk | General Material Machining Solutions | 4 | 04-27-2008 04:03 PM |
| Cutting Aluminum or copper? | Siren | JGRO Router Table Design | 1 | 02-23-2007 12:38 PM |
